Anybody replace the 15" diameter wooden steering wheel with a modern day quick release wheel of the same size? What brand of wheel and release mechanism did you buy and where? Are there any pitfalls to avoid while doing the installation? How big in diameter is the grip area of the steering wheel? I need this for thief prevention plus my original steering wheel is starting to rack slightly on the track.
-Keith
Mountney do quick release hubs, a bit pricey at around ?80. You could email them at [email protected] and see if they do one for an Elan/Spitfire/Herald.
There is also these guys at http://www.rallydesign.co.uk/catalog/index…p?cPath=900_906
although I don’t know anything about them.
Carl
Only problem I can see is the sticker shock. Good ones cost a small fortune. Hope I can keep my mouth shut when I go for it and lie convincingly when my wife interrogates me on how much it cost. She can see through me like I’m completely transparent. :blink:
OK, I’ll bite. No, but I did put a very late model Spitfire wheel on my S1 for a while and loved it. Still had to loosen the nut and take it off to change to my original 15" wooden wheel. Pitfalls? Grip area in diameter dimensions? Do you mean how big around is it? What thief is stealing what? Rack on the track? I’m lost…
To rack means it’s come loose. As I turn the steering wheel back and forth there is a small amount of angular play when changing directions. Okay for driving on the public roads. Definitely degrades the tactile feedback when at speed on the track. Kickback through the steering system to the steering wheel is dampened by the racking so I can’t feel what the car is doing as well as I should be able to do. This is not a serious safety issue just one of driver preference.
Any play in steering column splines/steering wheel is a straight MOT failure in UK!
…driving a race car with a loose steering wheel?
Actually a little clocking play is quite common on a racecar with a quick-release steering wheel. The ones which have no play are extremely expensive.
I’ve called around inquiring about a quick release hub to fit the Triumph Spitfire steering column and have come up with nothing. Looks like I’ll have to weld on the flange to the steering shaft cause there aren’t any direct bolt-on ones to buy. My question is the original steering shaft hardened steel? The reason I ask is the column has the safety collapsing feature were a clamp bears against a flat on the steering shaft and it’s designed to slide if enough force is applied. What diameter is that shaft exactly in the area of the clamp? I don’t want to butcher my original stuff so I’ll make a new one. TIA!
Check IO products in the US. http://www.ioportracing.com. They have several solutions and adaptors.
Jerry
Persistance has paid off afterall. Finally found the design of quick release hub mechanism that makes sense. Recognized it instantly because it’s the way I would have approached this design concept a second time around. I’ve got the benefit of hindsight here because I built a loose piece of crap one for our racecar years ago. Just hoping the as-built quality is as good as the design concept. TEKNIQ lists the adapter hub for the Triumph Spitfire steering column but they have never sold one before. Was informed I’m the first one to go for the Street version on an early Elan. Appears their collapsible adapter would move the steering wheel towards me by another few inches from the looks of them. I’ll probably build my own replacement steering shaft and mating flange so the steering wheel position stays where it is now. Even though I’m strapped into a four-point harness having the wheel just a few inches closer to my chest makes me nervous safety-wise.
http://www.tekniqauto.com/US/snapoff/SOFaq.htm
http://www.tekniqauto.com/US/home.htm Check on 'Snap-Off System at bottom.
The 41 is going to get a Snap-Off Racing version upgrade. Maybe they would make me a custom one to fit the bolt pattern of the original steering wheel. I’ll ask next week.
Looks like the tough part of this is finding a 380mm steering wheel I like. Need the leverage with 7 degrees of caster and no caster adjustment to keep the car from veering off the road due to the crown. Wished you made that adjustable Chunky!
p.s. Kinda of a lame name for a steering wheel device don’t you think? :huh:
Okay, Tekniq is having the adapter hub made for me which will bolt directly onto the Elan’s steering column. Supposely the hub is short enough so with a steering wheel which is not dished, the stacked assembly will end up at the same distance from me as the original wheel. The hub is $54. Gee, I’m going to have a functioning center horn button too. This is to easy.
Had to settle for a MOMO steering wheel which is only 13.5" (342mm) in diameter. They list it as being actually 350mm but it shrunk somewhat. Figured finding a 15" (380mm) diameter wheel would be the easy part but I was sadly mistaken. The only ones I could find were wooden ones. Better safe than sorry.
Last item is a fuel cell. My wife is going to kill me… :blink:
Received the Tekniq quick release steering wheel hub today. Build quality and function (no play) looks to be superb. If I get up early enough tomorrow maybe I can install it before leaving for Reno and the WCLM trackday.
Installed the steering wheel this morning in 45 minutes without any problems. The splined hub fit the Triumph Spitfire steering column perfectly. The wheel moved towards me by an 1 inch as measured on the backside to the dash. The horn worked first try. I’ll have to find a Lotus Emblem horn button that fits this Momo steering wheel. At this point I can highly recommend this setup. I’m most pleased with this well designed and well made Canadian product.
Hi Keith,
I just ordered one of these for my Sprint autocrosser along with a tekniqauto hub thanks to the research you did. Looking forward to many FTD’s.
http://www.sparcousa.com/psteering_comp.asp?id=452
http://www3.telus.net/public/miketodd/auto%20c.jpg
Hi Mike,
Nice car! Well the new steering wheel on my 26 has been track tested and it passed with flying colors. Definitely going to buy the racing version Tekniq hub and retrofit onto the 41’s original steering wheel.
-Keith
Hey Mike,
What wheels do you have on your car?
Keith,
Great new web format,eh? Thanks to whoever is responsible.
The make of the wheels is unknown to me. I bought them from a guy in Toronto about 20 years ago. They are 5.5"X13 knockoff mags.
Someone asked if they were Maglite wheels but I can’t find any stampings on them. They require an adapter to be threaded onto the original hub which increases the track.
Anyone out there know anything about this?
To me they look very much as though they are the British made “Revolution” wheels. I’m not sure if tthe company is still in business.
John.
