EF - Engine - Cams & Valves
Item Lotus # All S1 S2 S3 S3 SS S4 S4FED SPRINT RHD LHD Description Change Point
Notes
Bulletin Reference
1 B026E0351 2 Camshaft - Std. Weber
C026E0351 2 Camshaft - Emission - U.K. Stromberg - S/E Weber
D026E0351 2 2 Camshaft - S/E Stromberg - Super S/E and Sprint
3 A026E6016 2 Plug
4 026E0303 4 Bearing - Camshaft, Rear
5 026E0003 16 Bearing - Camshaft
6 A026E6024
(105E6256B)
2 Sprocket - Inlet/Jackshaft
7 026B0305 1 Sprocket - Exhaust
8 026B0016 2 Washer, Sprocket to Camshaft
9 A026E6094 2 Washer, Sprocket to Camshaft
10 026E0304 2 Bolt, Sprocket to Camshaft
11 A026E6023
(E93A6253)
2 Dowel - Sprocket to Camshaft
12 026E0007 1 Timing Chain
13 026E0012 1 Bracket - Chain Tensioner
14 026E0011 1 Pivot Pin - Chain Tensioner
15 026E0048
(AGS1138B)
1 Crush Washer
16 02E0013 1 Pin
17 026E0707 1 Sprocket Assembly
18 026B0381 1 Sprocket Wheel
19 026E0382 1 Bush - Sprocket Wheel
20 026E0706 1 Adjuster Screw Assembly
23 026E0391 1 Adjusting Nut
24 026E0392 1 Washer - Adjuster
21 026E0008 1 Bolt, Chain Tensioner
22 A026E6098 1 Crush Washer, Chain Tensioner
25 026E0009 1 Spring, Chain Tensioner
26 026E0010 1 Plunger, Chain Tensioner
27 YUFN050F 1 Nut, Chain Tensioner
28 A026E0014 1 Chain Guide (vibration damper)
29 A026E6059 2 Screw - Chain Guide
30 026E0352 1 Jackshaft
31 A026E6036 1 Tnrust Plate
32 A026E6026
(105E6269E)
2 Bolt - Sprocket to Jackshaft
33 A026E6037
(105E6255)
1 Bolt Retainer
34 105E261E 1 Liner - Front - Jackshaft
35 105E6262E 1 Liner - Centre - Jackshaft
36 105E6263E 1 Liner - Rear - Jackshaft
37 026E0017 1 Adaptor - Jackshaft
38 026E0018 1 Dowel - Adaptor to Jackshaft
39 A026E6025
(105E6258B)
1 Retainer, Jackshaft Sprocket to Jackshaft
40 A026E6041
(20366S2)
2 Bolt, Jackshaft Sprocket to Jackshaft
41 A026E0019 4 Valve - Inlet
B026E0019 4 Valve - Inlet
B026E0020 4 Valve - Exhaust (replaced by B026B0020)
42 B026B0020 4 Valve - Exhaust
43 A026E0312 4 Valve Seat Insert - Inlet, Std.
A026E0124 4 Valve Seat Insert - Inlet, Std.
A026E0312A 4 Valve Seat Insert - Inlet, 0.005" O/S
A026E0125 4 Valve Seat Insert - Inlet, 0.005" O/S
A026E0312B 4 Valve Seat Insert - Inlet, 0.010" O/S
A026E0126 4 Valve Seat Insert - Inlet, 0.010" O/S
A026E0312C 4 Valve Seat Insert - Inlet, 0.015" O/S
A026E0126 4 Valve Seat Insert - Inlet, 0.015" O/S
44 A026E0313 4 Valve Seat Insert - Exhaust, Std.
A026E0313A 4 Valve Seat Insert - Exhaust, 0.005" O/S
A026E0313B 4 Valve Seat Insert - Exhaust, 0.010" O/S
A026E0313C 4 Valve Seat Insert - Exhaust, 0.015" O/S
45 A026B0314 4 Valve Guide - Inlet, Std.
A026B0314A 4 Valve Guide - Inlet, 0.001" O/S
A026B0314B 4 Valve Guide - Inlet, 0.005" O/S
A026B0314C 4 Valve Guide - Inlet, 0.006" O/S
46 A026E0315 4 Valve Guide - Exhaust, Std.
A026E0315A 4 Valve Guide - Exhaust, 0.001" O/S
A026E0315B 4 Valve Guide - Exhaust, 0.005" O/S
A026E0315C 4 Valve Guide - Exhaust, 0.006" O/S
47 A026E6018
(111945-ES)
8 Circlip - Valve Guide
A026E0023 8 Valve Spring - Inner (replaced by B026E0023)
48 A026E0023 8 Valve Spring - Inner
A026E0022 8 Valve Spring - Outer
49 B026E0022 8 Valve Spring - Outer
50 A026E0316 8 Washer - Valve Spring Seat
51 A026E0021 8 Retainer - Valve Spring
52 026E0045 16 Collet - Valve Spring
53 A026E0025(65) AR Shim, 0.065 ins.
A026E0025(66) AR Shim, 0.066 ins.
A026E0025(67) AR Shim, 0.067 ins.
A026E0025(68) AR Shim, 0.068 ins.
A026E0025(69) AR Shim, 0.069 ins.
A026E0025(70) AR Shim, 0.070 ins.
A026E0025(71) AR Shim, 0.071 ins.
A026E0025(72) AR Shim, 0.072 ins.
A026E0025(73) AR Shim, 0.073 ins.
A026E0025(74) AR Shim, 0.074 ins.
A026E0025(75) AR Shim, 0.075 ins.
A026E0025(76) AR Shim, 0.076 ins.
A026E0025(77) AR Shim, 0.077 ins.
A026E0025(78) AR Shim, 0.078 ins.
A026E0025(79) AR Shim, 0.079 ins.
A026E0025(80) AR Shim, 0.080 ins.
A026E0025(81) AR Shim, 0.081 ins.
A026E0025(82) AR Shim, 0.082 ins.
A026E0025(83) AR Shim, 0.083 ins.
A026E0025(84) AR Shim, 0.084 ins.
A026E0025(85) AR Shim, 0.085 ins.
A026E0025(86) AR Shim, 0.086 ins.
A026E0025(87) AR Shim, 0.087 ins.
A026E0025(88) AR Shim, 0.088 ins.
A026E0025(89) AR Shim, 0.089 ins.
A026E0025(90) AR Shim, 0.090 ins.
54 026E0024 8 Tappet
