EC - Engine - Oil Pump
Item Lotus # All S1 S2 S3 S3 SS S4 S4FED SPRINT RHD LHD Description Change Point
Notes
Bulletin Reference
A026E6001 1 Oil Pump Assembly
1 E81/CF/l 1 Body and Oil Pressure Relief Valve
2 105E6663D 1 Plunger - Presure Relief Valve
3 105E6654 1 Spring - Pressure Relief Valve
4 105E6653B 1 Retainer - Pressure Relief Valve
5 105E6551 1 Gear - 0i1 Pump Drive
6 72432-S 1 Pin - Gear to Shaft
7 105E6608A 1 Rotor and Shaft Assembly
8 105E6616B 1 Cover
9 20344-S7 4 Bolt, Cover to Body
10 34825-S7 4 Washer, Cover to Body
11 87066-S 1 ‘O’ Ring - Cover to Body
12 A026E6028
(105E6659)
1 Gasket, Body to Cylinder Block
13 A026E6042
(20386-ES2)
3 Bolt, Body to Cylinder Block
14 036M6286
(34806-S7)
3 Washer, Body to Cylinder Block
15 A026E6073
(EIADKN18688B)
1 Gasket - Oil Filter
16 036E6005 1 Element - Oil Filter
17 036E6004 1 Oil Filter Assembly
18 A026E6074
(115827-ES8)
1 Bolt, Oil Filter to Body
19 116087ES 1 Washer, Oil Filter to Body
A036E6029 1 Oil Pump Assembly
20 2735E6600 1 Body and Oil Pressure Relief Valve
21 2735E6714B 1 Oil Fitter Assembly
22 2735E6608A 1 Rotor and Shaft Assembly
11 87066ES 1 Seal Ring
23 2735E6616A 1 Cover
9 20344S 3 Bolt, Cover to Body
10 34825S 3 Washer, Cover to Body
