EC - Engine - Oil Pump +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
A026E6001 1 Oil Pump Assembly
1 105E6600 1 Oil Pump Pressure Releif Valve
2 105E6663D 1 Plunger - Pressure Releif Valve
3 105E6654 1 Spring - Pressure Releif Valve
4 105E6653B 1 Retainer - Pressure Releif Valve
5 105E6551 1 Gear
6 105E724325 1 Pin
7 105E6608A 1 Rotor and Shaft Assembly
8 105E6616A 1 Cover
9 20344S 4 Bolt, Cover to Body
10 34825S 4 Washer, Cover to Body
11 87066ES 1 Seal Ring
12 A026E6028
(105E6659)
1 Gasket, Body to Cylinder Block (Both Types)
13 A026E6042
(20386S2)
3 Bolt, Body to Cylinder Block (Both Types)
14 X036M6246
(34806S2)
3 Washer, Body to Cylinder Block (Both Types)
15 A026E6073
(EIADKN18688B)
1 Gasket
16 036E6005 1 Element - Oil
17 036E6004 1 Oil Filter Assembly
18 A026E6074
(115827ES)
1 Bolt - Filter Bowl to Body
19 A026E6118 1 Washer - Filter Bowl to Body
A036E6029 1 Oil Pump Assembly From ?
20 2735E6600 1 Oil Pump Body & Pressure Relief Valve
21 2735E6714B 1 Oil Filter Assembly
22 2735E6608A 1 Rotor and Shaft Assembly
23 2735E6616A 1 Cover
9 20344S 3 Bolt, Cover to Body
10 34825S 3 Washer, Cover to Body
