Earthing points
Hi all. Just a quick one I hope. Where do the earth straps go in the engine bay - might sound a bit dumb but mine weren’t fitted when I got the car.
I’ve read the manual and been left a tad confused.
I think there should be a strap from the engine to the left hand suspension upright chassis bolt. Where does this fit onto the engine?
The dashboard is earthed to the left hand centre body to chassis bolt.
The battery is earthed to the left hand body to chassis bolt.
The coil is earthed to the oil pump.
The steering rack is earhed to one of the u bolts.
If anyone has any suggestions that would be appreciated.
Thanks.
Sean.
The engine earth on my car is made across the nearside mount to the chassis with a braided strap.
A bit like this. (just a bit tidier perhaps)
So that’s where that little earth strap goes. I’ve had it lying around since I bought the car. Fantastic. Just the help that I needed. I’m sure you didn’t have that photo just lying around so thanks for the help. I’m sure that mine will be no tidier once fitted. Thanks both of you for your help.
Ok, now I obviously put that strap away so that I wouldn’t lose it…
All the best.
Sean.
