Item | Lotus # | All | S1 | S2 | S3 | S3 SS | S4 | S4FED | SPRINT | RHD | LHD | Description | Change Point Notes Bulletin Reference |
A026E0701 | 1 | 1 | Engine Assembly - Weber | Upto Engine No. LP7464 | |||||||||
B026E0701 | 1 | 1 | Engine Assembly - Weber | Upto Engine No. LP7464 to 7799 | |||||||||
C026E0701 | 1 | 1 | Engine Assembly - Weber | From Engine No. LP7800 | |||||||||
D026E0701 | 1 | 1 | Engine Assembly - | ||||||||||
G026E0701 | 1 | Engine Assembly - Stromberg S.E. | |||||||||||
K026E0701 | 1 | 1 | 1 | Engine Assembly - Stromberg S.E. | |||||||||
L026E0701 | 1 | Engine Assembly - Stromberg Super S.E. | |||||||||||
N026E0701 | 1 | Engine Assembly - Weber S.E. | |||||||||||
026E0700 | 1 | Engine Assembly - Short Motor Assembly | Upto Engine No. LP7799 | ||||||||||
A026E0700 | 1 | Engine Assembly - Short Motor Assembly | From Engine No. LP7800 | ||||||||||
1 | 116E6675A | 1 | Oil Pan | Upto Engine No. LP7799 | |||||||||
125E6675A | 1 | Oil Pan | From Engine No. LP7464 to LP7799 | ||||||||||
A026E6083 (2731E6675A) |
1 | Oil Pan | From Engine No. LP7800 | ||||||||||
EB6730 | 1 | Drain Plug | Upto Engine No. LP7799 | ||||||||||
2 | 2731E6730 | 1 | Drain Plug | From Engine No. LP7800 | |||||||||
105E6734 | 1 | Seal Ring - Oil Drain Plug | Upto Engine No. LP7799 | ||||||||||
3 | 2731E6734 | 1 | Seal Ring - Oil Drain Plug | From Engine No. LP7800 | |||||||||
4 | 105E6711B | 1 | Gasket - Oil Pan LH | Upto Engine No. LP7799 | |||||||||
105E6710B | 1 | Gasket - Oil Pan RH | Upto Engine No. LP7799 | ||||||||||
A026E6084 (2730E6711A) |
1 | Gasket - Oil Pan LH | From Engine No. LP7800 | ||||||||||
A026E6085 (2730E6710A) |
1 | Gasket - Oil Pan RH | From Engine No. LP7800 | ||||||||||
5 | A026E6082 (2733E6722A) |
1 | Packing - Oil Pan Front | From Engine No. LP7800 | |||||||||
105E6701 | 1 | Packing - Oil Pan Rear - Lower | Upto Engine No. LP7799 | ||||||||||
105E6702 | 1 | Packing - Oil Pan Rear - Upper | Upto Engine No. LP7799 | ||||||||||
6 | A026E6086 (2730E6723A) |
1 | Packing - Oil Pan Rear | From Engine No. LP7800 | |||||||||
43263-ES2 | - | Replaced by A026E6064 | |||||||||||
7 | A026E6064 (20308S8) |
16 | Bolt, Oil Pan to Cylinder Block | ||||||||||
A026E6051 (45510S2) |
2 | Bolt, Oil Pan to Cylinder Block | |||||||||||
8 | A026E6117 (11041ES8) |
16 | Washer, Oil Pan to Cylinder Block | ||||||||||
9 | 2724E6701A | 1 | Seal - Crankshaft Rear | From Engine No. LP7800 | |||||||||
105E6369 | 1 | Gasket - Oil Seal Housing | Upto Engine No. ? | ||||||||||
10 | 273E06344A | 1 | Gasket - Oil Seal Housing | From Engine No. ? | |||||||||
115803-ES8 | 2 | Bolt, Oil Seal Housing to Cylinder Block | Upto Engine No. ? | ||||||||||
11 | A026E6047 (20366S2) |
A026E6047 | 4 | Bolt, Oil Seal Housing to Cylinder Block | From Engine No. ? | ||||||||||
12 | A026E6091 (34806S2) |
4 | Washer, Oil Seal Housing to Cylinder Block | From Engine No. ? | |||||||||
13 | A026E0708 | 1 | Cylinder Block | Upto Engine No. LP7463 | |||||||||
B026E0708 | 1 | Cylinder Block | From Engine No. LP7464 to LP7799 | ||||||||||
C026E0708 | 1 | Cylinder Block.From Engine No. LP7800 | |||||||||||
14 | A026E6090 (35300S) |
2 | Plug - Water Jacket | ||||||||||
E0TA8115 | - | Replaced by A026E6032 (Possible manual typo - A023E6023?) | |||||||||||
15 | A026E6023 (87786ES) |
1 | Drain Cock - Cylinder Block | ||||||||||
16 | A026E6031 (87837ES2) |
3 | Plug - Oil Gallery | ||||||||||
A026E6123 (353052ES) |
- | Replaced by A026E6017 - use up old stocks first | |||||||||||
A026E6017 | 1 | Plug - Oil Gallery - Transverse | |||||||||||
17 | 9D295 | 1 | Connector - Oil Pressure Gauge | ||||||||||
A026E6034 (357966-S) |
1 | Plug - Oil Gallery Drain | |||||||||||
105E66-15B | 1 | Pipe - Oil Pimp ‘pick-up’ with Screen | Upto Engine No. LP7463 | ||||||||||
18 | A026E6089 (2730E6615A) |
1 | Pipe - Oil Pimp ‘pick-up’ | From Engine No. LP7464 | |||||||||
19 | A026E6088 (2730E6623A) |
1 | Screen Assembly - Oil Pump ‘pick-up’ | From Engine No. 7464 | |||||||||
E55-CF-1 | 1 | Plate - Oil Pump Connection | Upto Engine No. LP7463 | ||||||||||
105E6646 | 1 | Pipe - Oil Return | Upto Engine No. LP7463 | ||||||||||
20 | 2730E6K656 | 1 | Pipe - Oil Return | From Engine No. LP7464 | |||||||||
109E6689 | 1 | Housing - Rear Oil Seal | Upto Engine No. LP7463 | ||||||||||
21 | 026E0384 | 1 | Housing - Rear Oil Seal | From Engine No. LP7464 | |||||||||
22 | 026E0034 | 1 | Breather Connection | ||||||||||
23 | A026E6106 (105E6397) |
2 | Dowel Pin - Clutch Housig to Cylinder Block | ||||||||||
24 | A026E6107 (105E6677) |
1 | Cover - Starter Motor | Upto Engine No. ? | |||||||||
A026B6125 (109E6677 |
1 | Cover - Starter Motor | From Engine No. ? | ||||||||||
105E7009 | 1 | Back Plate | Upto Engine No. ? | ||||||||||
25 | A026E6108 (691E6366A) |
1 | Back Plate - Upper | From Engine No. ? | |||||||||
26 | A036E6017 (2730E6382) |
1 | Back Plate - Lower | From Engine No. ? to ? | |||||||||
A026E6110 (2735E7007A) |
1 | Back Plate - Lower | From Engine No. ? | ||||||||||
27 | 026E0374 | 1 | Engine Mounting RH | Upto Engine No. ? | |||||||||
054B6000 | 1 | Engine Mounting LH | Upto Engine No. ? | ||||||||||
026E6011 | 2 | Engine Mounting | From Engine No. ? | ||||||||||
28 | 026E0375 | 4 | Spacer Bush | ||||||||||
29 | A026E6078 (20326S7) |
4 | Bolt, Engine Mount to Block | ||||||||||
30 | 112981ES | 4 | Bolt, Engine Mount to Block | ||||||||||
31 | 3487S | 8 | Washer, Engine Mount to Block | ||||||||||
XUFS0614 | 4 | Bolt, Engine Mount to Chassis | |||||||||||
YUFN060F | 4 | Nut, Engine Mount to Chassis | |||||||||||
A06W1207 | 4 | Washer, Engine Mount to Chassis | |||||||||||
32 | 026E0004 | 1 | Timing Case | ||||||||||
33 | 026E0005 | 1 | Gasket - Timing Case | ||||||||||
34 | A026E6045 | 1 | Set Screw, Timing Case to Cylinder Block | ||||||||||
35 | 34505 | 1 | Washer, Timing Case to Cylinder Block | ||||||||||
026E0705 | 1 | Timing Case Cover Assembly | Upto Engine No. 7799 | ||||||||||
A026E0705 | 1 | Timing Case Cover Assembly | From Engine No. 7800 | ||||||||||
36 | 026E0361 | 1 | Timing Case Cover | Upto Engine No. 7799 | |||||||||
A026E0361 | 1 | Timing Case Cover | From Engine No. 7800 | ||||||||||
37 | A026E6051 (45512S2) |
1 | Bolt, Timing Case to Cylinder Block | ||||||||||
38 | A026E6054 (34805S2) |
6 | Washer, Timing Case to Cylinder Block | ||||||||||
39 | 036M6246 (34806S2) |
3 | Washer, Timing Case to Cylinder Block | ||||||||||
40 | A026E6057 (45510S2) |
4 | Bolt, Timing Case to Cylinder Block | ||||||||||
41 | A026E6056 (45511S2) |
5 | Bolt, Timing Case to Cylinder Block | ||||||||||
42 | PT/D086/11/2 | 3 | Nut, Timing Case to Cylinder Block | ||||||||||
43 | A026E6095 (20386ES) |
44 | A036M6243 (34746ES) |
2 | Washer, Timing Case to Cylinder Block | ||||||||||
45 | 20513S | 1 | Bolt, Timing Case to Cylinder Block | ||||||||||
46 | A026E6050 (44715S7) |
47 | 026E0049 | 1 | Washer, Timing Case | ||||||||||
48 | 026E0047 | 1 | Plug, Timing Case | ||||||||||
49 | 34802 | 1 | Washer - Timing Case Bolt | ||||||||||
026E0383 | 1 | Replaced by A026E0383B | |||||||||||
50 | A026E0383B | 1 | Dip Stick | ||||||||||
026E0082 | AR | Gasket Set, Decarbonising Set (Weber) | |||||||||||
B026E0082 | AR | Gasket Set, Decarbonising Set (Stromberg) | |||||||||||
026E0085 | AR | Gasket Set, Lower Engine | Upto Engine No. LP7799 | ||||||||||
026E0086 | AR | Gasket Set, Lower Engine | From Engine No. LP7800 | ||||||||||
026E0763 | AR | Gasket Set, Overhaul | From Engine No. LP7800 |
