door locks
I have recently bought a '72 +2 which has (to my eyes) really unusual circular doorlocks (see attached pictures)- one of whih doesn’t work. I’ll delve into the insides of the door but wonder - are these the correct locks? Or are they some strange thing fitting by a previos owner?
Yes the handles are correct unless you have a 1967 or early 1968 car in which case they are not.
These handles are from a Series 1+2 Jaguar XJ, have a look on ebay Item number: 310070582211. I bought 4 handles in mint condition for ?7, at that price I had to have them even though mine are good :slight_smile:
The door lock is not original, it is a after market high security lock we used to fit on work vans in the 1990’s. It was sold on the fact that you could not put a screwdriver in it and force it like the original ones. I can and have opened my +2 with a wire coathanger so no need for added security. :slight_smile:
Pic of my lock attached.
Hope this helps
Jason
Thanks for the very fast & helpful response, I’ll fiddle around inside and get the jammed lock to work!
Hi New to +2,
I have much the same problem with a similar deadlock on a +0.
If you have time, a picture showing the linkage from the lock to the door pull would be useful … particularly, the orientation of the cam on the lock.
Many thanks.
Stuart.
A couple of people have asked for photos of the insides of the doorlock mechanism - so here is one! Hope it helps
attachment didn’t work - try again
Thanks for the photo … hopefully it’ll help me out.
Stuart.
Stuart
These people http://www.faparkes.co.uk/ actually supply new locks for the doors with are identical to the originals complete with new keys etc !! all fr about 6 Quid !! :wink:
Thye are under Locks & Lock Cylinders / Cam / comp Key Op
You can get then with straight or cranked operating levers etc
Hope this helps you
Should the +2 have a metal shim fitted inside the door skin to prevent the glassfibre from cracking-like the Elan does?
