Could someone advise on the pro?s and con?s of an airbox? I am presently restoring a 1970 S4 which has come with no airbox but with a pair of K&N filters. The K&N website suggests that these are not suitable (legal?) for road use but I wonder whether that relates to use in the US only.
Uncleaned air increases damage to the cylinder walls via small, grinding particles resulting in less engine life. Imagine You are driving down a road in dry summer and a cloud of sand comes along…
Airboxes/long suction lines increase the torque of engines but make them a little more unwilling to rev. Some high class modern cars use switchable airboxes with long/short suction lines which operate via power demand from ECU. An air box can also influence the filling via resonance charging - air suction from one cylinder stops, pressure in airbox increases and next cylinder is filled with slightly compressed air. Also carburettors have to be set up for airbox type.
I am just in the process of converting from an airbox to a pipercross system with other lotuselan members have had good success with (Steveww). Ray Dent is actually running a close-out on them right now for $149; rdent.com/pages/specials.html They will accomodiate short velocity stacks, which I’m looking forward to seeing if they make a difference. Dan '70 S4 SE
Using air filters bolted directly to the carburettors will make them suck in warm air from around the engine. The original layout was designed to suck cool air from the nose, to give ‘better running’ - see the chapter on ‘Air Filtration & Silencing’ in Miles Wilkins’ Lotus Twin-Cam Engine book.
If the engine is standard, I say stick with what Lotus intended - they generally knew what they were doing…
I inherited pseudo K&N filters which I ditched ASAP, after sourcing an airbox.
I now run with the correct airbox (no filter) and a run of 4 inch diameter pipe down into the nose, connected there to a Pipercross filter.
I’m reasonably happy, but there’s two things I wish to try:
adapt the airbox so that there’s more space in front of no. 4 trumpet (and to a lesser degree, no. 3 trumpet).
then remove the nosecone Pipercross filter and replace (temporarily) with stockings/tights (eg), and give it a good blast.
The reason: I’m not at all sure that my Sprint is breathing optimally. It’s free-revving fine, but the acceleration right up to the top end is not how I remember the twin-cam. That’s the reason for the second test.
There could be other reasons, of course, for the seeming lack of blistering acceleration all the way up the top end (my memory, not the least), but I will follow this course for now.
Just to say that I also concur with Matthew, in that Webers need a cool supply of air.
Conversely, don’t forget to dissipate the hot air from the exhaust manifold area.
Not yet having removed the head, I’m presuming an original configuration. When it does have to be removed, it will be breathed on a la Mr Vizard … should improve breathing no end.
Here’s a link from someone in the group that tested the theory of sucking in hotter air from the engine compartment vs the front grill and found no difference in temperature.
I had a pair of K&N pancake style filters on my Elan for a while. The induction noise was deafening! I early on switched to the standard air box with a K&N cone filter in the nose. Much quieter, I could actually listen to my CD when I was not enjoying the sound of the twink’s exhaust.
My vote is for the cone filter. Also keeps the engine looking original. Yep, I’m one of those originality counts types. And from the number of first places my Elan has won I think many others think the same.
As Tim has already pointed out, the airbox is a useful (and designed?) barrier 'twixt petrol and sparks - on the twinc, any spitting back or fuel seepage will drop straight on to the handily-placed dizzy and leads which may well be, unbeknown to you, arcing quietly away to themselves!
Sidedrafts also have a tendency to produce a “haze” of petrol vapour outside the trumpets (something to do with the pulses in the induction system I think)
My worry has always been that if this haze gets close to a spark… Booom!
This subject seems to crop up every couple of years, last time I asked if anyone on this forum had experience of a fire with non-standard air-cleaners. Zero response.
Bear in mind that K&N filters have a metal casing and have metal gauze, which flames cannot pass through (basic school physics), the standard airbox is one half metal, one half glass-fibre. Which is more likely to catch fire?
Max bhp is achieved with large flared trumptes, curved (preferrably parabolically) all the way around to the sides, with no sharp edges. Unfortunately, this doesn’t fit behind the standard airbox (No. 4 inlet is shrouded quite considerably already). I made a large airbox to fit an S4 backing plate. After much moaning and gnashing of teeth (and trimming of the top gaurd lip and bonnet support), I managed to get it to slip in and out over the trumpets. It has a 100mm snorkel to a large K&N filter in the nose and works quite well.
Another club member has made a more modest design to fit on an S123 backing plate without any trimming, but nicely cures any oiling up on No. 4 plug. I believe he sells them for a modest sum, if anyone is interested (let me know).
My system dyno’s at 190bhp (1700cc), but any airbox system would perform better (bhp and filtration) than socks or individual filters IMHO.
Logic suggests, Elansprint71, that anyone who might have responded in the positive to your ‘has your lack of airbox caused a fire?’ survey wouldn’t have done so because, having had their Elan destroyed by fire, wouldn’t be using this forum anyway!
Hatman, yeah, you could be right! In all the time I’ve been with Elan.Net (which must be about five years now) I can only recall two folks mentioning fires and, iirc, both of those were due to electrics.
Hi, I posted a picture on Things in common " airbox seal" Sept. 6th of what my new rubber seal looked like. Last weekend I attended the All British car Meet in Palo Alto CA. On the way there I started smelling gas. It turned out the bolt had loosen on the airbox and the rubber seal came off in places. Re-sealed the airbox and installed a locknut and now it is sealed and no gas smell. Can’t help thinking that if I could smell fuel inside my coupe there was a risk of a fire. I was told of a fire from the leaky airbox that was put out with out too much damage.
I too have installed a K&N filter in front of the radiator for cool air. It seems to be working well.
Patrick, if the club member who has made a larger fiberglass airbox and still is offering them, I would be interested in one.
Sarto
For what it’s worth, Tony Thompson does a deeper airbox made of GRP to smooth the flow to the trumpets. It uses a large bore air hose and a massive cone type filter. I installed his system locating the filter in front of the rad.
His gear is expensive but well designed.
I’m also using his large bore road exhaust system.
The combination is very succesful. The engine breathes much better and seems now to be quicker to respond.
Help me understand why, if there’s a concern about Webers belching fire, someone would use GRP to make an airbox? This seems counterintuitive to me.
AFA Lotuses having carb fires, unless there’s a good reason NOT to run an airbox, seems to me that it’s an ounce of prevention thing. When I was a tad working a Porsche-Audi dealership, Porsche 912s (4 cyl) would regularly pop spectacular flames. Porsche re-designed the air filter a couple of times because the built up vapors would make the fireworks even more spectacular.
I’m not sure I should admit this but I ran my S2, from '75 until it was pinched in '89, without an airbox or filters of any kind. This was dailycommuting into London from Surrey with regular weekend trips around the country’s race circuits mechanicing 26r and 23s, most of which ran without as well. In later years we have used ‘socks’ or elongated ‘pancakes’ on the racers because they became available. I never had a whiff of fire although there was the odd minor ‘explosion’ sometimes causing a little puff of smoke from the gap between the bonnet and the wing. Guess I was lucky? I must say that there was no sound deadening on the underside of the body so there was perhaps less potential for fire. Neither was the car trimmed so, yes, it was quite noisy but SWMBO loved it on the motorway as it sent her off to sleep. Yes, really! Now the family has grown up and the new garage/workshop is about finished, it is soon time to start the rebuild. Just 17 years off the road! Whether I fit an airbox or not I have yet to decide.
