Distributor removal
Is it possible/feasible to remove the distributor (23D4) from a Twink without removing the Webers?
Yes, its no problem just a bit finicky.
Thanks, Brian. Might be better than trying to replace the points and condenser with it in the car.
:sunglasses:
Absolutely, but now a 1000 people will tell you to fit electronic ign :laughing:
I’m beginning to wonder if sticky centrifugal weights in my distributor are the cause of my engine’s very real reluctance to start when it has been unused for a few days.
I’ve tried just about everything else.
In my experience, the engine will start fairly easily with ign timing off by 20 degrees (crank) either way - which is roughly the total distance moved by the centrifugal advance - so it sounds unlikely to me.
I would check the theory out by just putting a strobe light on while cranking the engine and see roughly where the timing is.
Also, if the weights are sticking to that degree, I’d expect to see quite a lot of jitter in the timing when using a strobe when the engine is running.
Paddy
TO REMOVE THE DIST ----JUST REMOVE THE DIST CAP —LOOSEN THE CLAMP and lift -------however it is wise to do this with the cams and pulley at tdc --front lobes out rear lobes in - timing marks in correct position -and to replace the dist follow the manual exactly ----the low tension wires adjacent to the block --make sure the slot in the rotor is at 6 o’clock as it will turn to the left [anti clock wise] into the correct position as it meshes - this will put #1 at the top slightly right and timing [1342] will be set in correct position — the clamps will be vertical in a line at 90 degrees with the block --put plug in the wire and rotate the dist it will spark confirming #1 plug -otherwise you will chase the thing around for hours trying to get it started—ed
