What is the part no`s of the 23D4 distributer cap ,the rightangle one .What size od are the leads
7mm
Lucas original number was 54412472, Lucas current number I think is
DDB 101, Intermotor ref is 44720, Commercial Ignition (CI) is XD65. That gives u a few choices. 7mm leads fit, 8mm will but you have to carefully drill out the holes in the cap !! jon
Triumphelan
Your lucky day,try ebay 4591486409
I’ve just completed this job myself, fitted the correct cap, copper leads, rotor arm and caps in place of a plug in cap, modern leads and god knows what rotor arm!
The entire job is very simple and costs in the region of ?25.
If you have difficulty obtaining parts let me know, or if you’d prefer to buy a bolt up kit also let me know I’ll supply one with pleasure.
Thanks John ,I`m onto it highest bid so far
