Item | Lotus # | All | S1 | S2 | S3 | S3 SS | S4 | S4FED | SPRINT | RHD | LHD | Description | Change Point Notes Bulletin Reference |
1 | A026J0001 | 2 | Disc - Rear | ||||||||||
2 | 026D0001 | 2 | Hub - Bolt-on Wheels | ||||||||||
3 | 036D6002 | 8 | Stud - Wheel Mounting | ||||||||||
036D0063 | - | Replaced by B036D0063 | Upto Chassis No. ?,Service Bulletin 1967/75 | ||||||||||
036D0064 | 1 | Replaced by B036D0064 | Upto Chassis No. ?,Service Bulletin 1967/75 | ||||||||||
4 | B036D0063 | 2 | Hub - Knock-on Wheels LH | Upto Chassis No. ?,Service Bulletin 1967/75 | |||||||||
B036D0064 | 2 | Hub - Knock-on Wheels RH | Upto Chassis No. ?,Service Bulletin 1967/75 | ||||||||||
5 | 036G0011 | 8 | Peg - Wheel Mounting | Upto Chassis No. ?,Service Bulletin 1967/75 | |||||||||
050G0011 | 8 | Peg - Wheel Mounting | Upto Chassis No. ?,Service Bulletin 1967/75 | ||||||||||
036D6001 | - | Replaced by 036D6017 | |||||||||||
036D6004 | - | Replaced by 036D6017 | Upto Chassis No. 7761 | ||||||||||
036D6005 | - | Replaced by 036D6017 | |||||||||||
036D6014 | - | Replaced by 036D6017 | |||||||||||
036D6015 | - | Replaced by 036D6017 | |||||||||||
6 | 036D6017 | 2 | Bearing - Outer | From Chassis No. 7762 | |||||||||
7 | 036D6003 | 2 | Bearing - Inner | From Chassis No. 7762 | |||||||||
8 | 036D6006 | 4 | Circlip | ||||||||||
9 | 036D6007 | 2 | Circlip | ||||||||||
10 | 036D0151 | 2 | Spacer - Rear Bearing | From Chassis No. 7762 | |||||||||
11 | A036D6019 | 2 | Nut, Hub to Drive Shaft | ||||||||||
12 | 026D0048 | 2 | Washer, Hub to Drive Shaft | ||||||||||
13 | A026D0003 | 2 | Drive Shaft - Outboard | Upto Chassls No. 7761 | |||||||||
B026D0003 | 2 | Drive Shaft - Outboard | From Chassis No. 7762 | ||||||||||
14 | 026D0002 | 2 | Key - Outboard Drive Shaft | ||||||||||
15 | 050D6003 | 1 | Hub/Damper Assembly LH | From Chassis No. 7762 | |||||||||
050D6004 | 1 | Hub/Damper Assembly RH | From Chassis No. 7762 | ||||||||||
026D0004 | - | Replaced by A026D6004 together with: | |||||||||||
1 off 036D6003 Bearing | |||||||||||||
1 off B026D0003 Drive Shaft | |||||||||||||
1 off 036D0151 Spacer | Upto Chassis No. 7761 | ||||||||||||
A026D0004 | 1 | Bearing Housing RH | From Chassis No. 7762 | ||||||||||
026D0004 | - | Replaced by A026D6005 together with: | |||||||||||
16 | A026D0005 | 1 | Bearing Housing RH | From Chassis No. 7762 | |||||||||
026D0007 | - | Replaced by 050D0006 | |||||||||||
17 | 050D0007 | 2 | Damper Unit | ||||||||||
18 | 026D0006 | 2 | Spring - Rear | ||||||||||
19 | 036D6013 | 2 | Bump Rubber | ||||||||||
20 | 036D6008 | 2 | Abutment - Spring | ||||||||||
21 | 026D0009 | 2 | Dust Cover | ||||||||||
22 | 026D0011 | 2 | Nut, Damper to Resilient Mounting | ||||||||||
23 | 036D6009 | 2 | Cotter Pin, Damper to Resilient Mounting | ||||||||||
24 | 026D0703 | 2 | Resilient Mounting | ||||||||||
25 | 026D0032 | 4 | Bolt, Resilient Mounting to Chassis | ||||||||||
L05W0000 | 4 | Washer, Resilient Mounting to Chassis | |||||||||||
26 | 026D0014 | 2 | Wishbone | ||||||||||
27 | 036D6010 | 4 | Bush - Wishbone, Inner | ||||||||||
28 | 036D6011 | 4 | Bush - Wishbone, Outer | ||||||||||
29 | A036D0190 | ||||||||||||
(W0001) | 2 | Bolt | Wishbone to Bearing Housing, Front | ||||||||||
YUFN070F | 2 | Nut | Wishbone to Bearing Housing, Front | ||||||||||
A07W1405 | 2 | Washer | Wishbone to Bearing Housing, Front | ||||||||||
30 | A036D0191 | ||||||||||||
(W0002) | 2 | Bolt | Wishbone to Bearing Housing, Rear | ||||||||||
YUFB070F | 2 | Nut | Wishbone to Bearing Housing, Rear | ||||||||||
A07W1405 | 2 | Washer | Wishbone to Bearing Housing, Rear | ||||||||||
31 | XUFB0740 | 4 | Bolt | Wishbone to Chassis | |||||||||
YUFN070F | 4 | Nut | Wishbone to Chassis | ||||||||||
32 | XUFB0752 | 6 | Bolt | Outboard Drive Shaft & Disc to Coupling | |||||||||
YUFN070F | 6 | Nut | Outboard Drive Shaft & Disc to Coupling |
