| Item | Lotus # | All | +2 | +2 FED | +2S | +2S FED | +2S 130 | RHD | LHD | Description | Change Point Notes Bulletin Reference |
| 1 | A026J0001 | 2 | Brake Disc - Read | ||||||||
| 2 | 050D0063 | 1 | Hub - Rear LH | ||||||||
| 050D6004 | 1 | Hub - Rear RH | |||||||||
| 4 | 050G0011 | 10 | Drive Peg | ||||||||
| 026D0004 | 1 | Bearing Hosuing, RH (replaced by A026D0004) together with: 1 off 036D6003 Bearing 1 off B026D0003 Outboard Drive Shaft 1 off 036D0151 Spacer |
Upto Chassis No. 0249 Bulletin: Parts 1967/88, 1968/57 Service 1968/11 |
| A026D0004 | 1 | Bearing Housing | From Chassis No. 0250 | ||||||||
| 026D0005 | 1 | Bearing Hosuing, LH (replaced by A026D0005) together with: 1 off 036D6003 Bearing 1 off B026D0003 Outboard Drive Shaft 1 off 036D0151 Spacer |
| 5 | A026D0005 | 1 | Bearing Housing, LH | From Chassis No. 0250 | |||||||
| 036D6001 | 4 | Bearing | Upto Chassis No. 0249 | ||||||||
| 7 | 036D6003 | 2 | Bearing- Inner | From Chassis No. 0250 | |||||||
| 036D6001 | 2 | Bearing - Outer (replaced by 036D6017) | From Chassis No. 0250 Bulletin:Parts 1968/57 |
| 036D6016 | 2 | Bearing - Outer (replaced by 036D6017) | |||||||||
| 8 | 036D6017 | 2 | Bearing - Outer | ||||||||
| 9 | 036D6007 | 2 | Circlip | ||||||||
| 10 | 036D0151 | 2 | Spacer | From Chassis No. 0250 | |||||||
| 036D0166 | 2 | Spacer (use with earlier type bearing - later type hosuing). | |||||||||
| 11 | 036D6006 | 4 | Circlip | ||||||||
| 12 | A026D0003 | 2 | Drive Shaft - Outboard | Upto Chassis No. 0249 | |||||||
| B026D0003 | 2 | Drive Shaft - Outboard | From Chassis No. 0250 | ||||||||
| 14 | 026D0002 | 2 | Key - Drive Shaft | ||||||||
| YUFN100F | - | Key (replaced by A036D6019), Hub to Drive Shaft | |||||||||
| 15 | A036D6019 | 2 | Nut, Hub to Drive Shaft | ||||||||
| A10W1409 | - | Washer (replaced by 026D0048), Hub to Drive Shaft | |||||||||
| 16 | 026D0048 | 2 | Washer, Hub to Drive Shaft | ||||||||
| J055 | 6 | Bolt - Brake Disc Coupling to Drive Shaft | |||||||||
| 18 | 050D0007 | 2 | Damper Unit | ||||||||
| 19 | 050D6003 | 1 | Damper/Bearing Housing LH | ||||||||
| 050D6004 | 1 | Damper/Bearing Housing RH | |||||||||
| 20 | 050D0006 | 2 | Road Spring | ||||||||
| 21 | 036D6013 | 2 | Bunp Stop | ||||||||
| 050D0154 | 2 | Spacer - Bump Limiting | From Chassis No. 1531 | ||||||||
| 22 | 036D6008 | 2 | Spring Abutment - Top | ||||||||
| 25 | 026D0011 | 2 | Nut - Damper to Resilient Mounting | ||||||||
| 26 | 036D6009 | 2 | Split Pin - Damper to Resilient Mounting | ||||||||
| 27 | 050D0014 | 2 | Wishbone | ||||||||
| 28 | 036D6010 | 4 | Bush - Wishbone - Inner | ||||||||
| 29 | 036D6011 | 4 | Bush - Wishbone - Outer | ||||||||
| 30 | 026D0703 | 2 | Resilient Mounting Assembly | Upto Chassis No. 1459 | |||||||
| A026D0703 | 2 | Resilient Mounting Assembly | From Chassis No. 1531 | ||||||||
| 026D0032 | 4 | Screw - Resilient Mounting to Chassis | |||||||||
| A036D0190 | 2 | Bolt, Wishbone to Bearing Housing Front | |||||||||
| YUFN070F | 2 | Nut, Wishbone to Bearing Housing Front | |||||||||
| YUFN070F | 2 | Nut, Wishbone to Bearing Housing Rear | |||||||||
| A036D0191 | 2 | Bolt, Wishbone to Bearing Housing Rear | |||||||||
| XUFB0740 | 4 | Bolt, Wishbone to Chassis | |||||||||
| YUFN070F | 4 | Nut, Wishbone to Chassis | |||||||||
| A07W0000 | 2 | Washer - Wishbone to Bearing Housing Front | |||||||||
| A07W0000 | 2 | Washer - Wishbone to Bearing Housing Rear | |||||||||
| 34 | 036G0006 | 2 | Nut - RH - Wheel Retaining | UK only | |||||||
| 036G0007 | 2 | Nut - LH - Wheel Retaining | UK only | ||||||||
| 36 | C036G0006 | 2 | Nut - RH - Wheel Retaining | Export only | |||||||
| C036G0007 | 2 | Nut - LH - Wheel Retaining | Export only |
