DA - Rear Suspension +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
1 A026J0001 2 Brake Disc - Read
2 050D0063 1 Hub - Rear LH
050D6004 1 Hub - Rear RH
4 050G0011 10 Drive Peg
026D0004 1 Bearing Hosuing, RH (replaced by A026D0004)
together with:
1 off 036D6003 Bearing
1 off B026D0003 Outboard Drive Shaft
1 off 036D0151 Spacer
Upto Chassis No. 0249
Bulletin:
Parts 1967/88, 1968/57
Service 1968/11
A026D0004 1 Bearing Housing From Chassis No. 0250
026D0005 1 Bearing Hosuing, LH (replaced by A026D0005)
together with:
Bulletin:
Service 1968/11
5 A026D0005 1 Bearing Housing, LH From Chassis No. 0250
036D6001 4 Bearing Upto Chassis No. 0249
7 036D6003 2 Bearing- Inner From Chassis No. 0250
036D6001 2 Bearing - Outer (replaced by 036D6017) From Chassis No. 0250
Bulletin:Parts 1968/57
036D6016 2 Bearing - Outer (replaced by 036D6017)
8 036D6017 2 Bearing - Outer
9 036D6007 2 Circlip
10 036D0151 2 Spacer From Chassis No. 0250
036D0166 2 Spacer (use with earlier type bearing - later type hosuing).
11 036D6006 4 Circlip
12 A026D0003 2 Drive Shaft - Outboard Upto Chassis No. 0249
B026D0003 2 Drive Shaft - Outboard From Chassis No. 0250
14 026D0002 2 Key - Drive Shaft
YUFN100F - Key (replaced by A036D6019), Hub to Drive Shaft
15 A036D6019 2 Nut, Hub to Drive Shaft
A10W1409 - Washer (replaced by 026D0048), Hub to Drive Shaft
16 026D0048 2 Washer, Hub to Drive Shaft
J055 6 Bolt - Brake Disc Coupling to Drive Shaft
18 050D0007 2 Damper Unit
19 050D6003 1 Damper/Bearing Housing LH
050D6004 1 Damper/Bearing Housing RH
20 050D0006 2 Road Spring
21 036D6013 2 Bunp Stop
050D0154 2 Spacer - Bump Limiting From Chassis No. 1531
22 036D6008 2 Spring Abutment - Top
25 026D0011 2 Nut - Damper to Resilient Mounting
26 036D6009 2 Split Pin - Damper to Resilient Mounting
27 050D0014 2 Wishbone
28 036D6010 4 Bush - Wishbone - Inner
29 036D6011 4 Bush - Wishbone - Outer
30 026D0703 2 Resilient Mounting Assembly Upto Chassis No. 1459
A026D0703 2 Resilient Mounting Assembly From Chassis No. 1531
026D0032 4 Screw - Resilient Mounting to Chassis
A036D0190 2 Bolt, Wishbone to Bearing Housing Front
YUFN070F 2 Nut, Wishbone to Bearing Housing Front
YUFN070F 2 Nut, Wishbone to Bearing Housing Rear
A036D0191 2 Bolt, Wishbone to Bearing Housing Rear
XUFB0740 4 Bolt, Wishbone to Chassis
YUFN070F 4 Nut, Wishbone to Chassis
A07W0000 2 Washer - Wishbone to Bearing Housing Front
A07W0000 2 Washer - Wishbone to Bearing Housing Rear
34 036G0006 2 Nut - RH - Wheel Retaining UK only
036G0007 2 Nut - LH - Wheel Retaining UK only
36 C036G0006 2 Nut - RH - Wheel Retaining Export only
C036G0007 2 Nut - LH - Wheel Retaining Export only
