Apparently this CV driveshaft has been on the car for a long time. In removing it to replace a torn boot, the inner cv came apart, ball bearings everywhere… I can’t seem to get it off. Have covered in penetrating oil and am taking the rest of night off. It seems like I just need to pry it apart along the seam, but am afraid I will damage. Suggestions. Thanks. Dan
The workshop manual mentions removal of a circlip before tapping out the drive shaft. I presume your cv driveshafts are machined to match the original doughnut versions, so the circlip will still be there.
Hope this helps.
Sean.
Perhaps some gentle pulls on a slide hammer, with some heat on the part that is holding the joint. I’m assuming that is what you are refering to, since I can’t see any other way to remove the bearing circlip in the diff case.
Greg Z
From picture, CV1, it appears that the aluminum housing has been “dented”, “peaned”. Perhaps the area has been used to pry against, which could push the metal into the “ID” of the bearing/snapring area, which will make the stub shaft hard to remove, as now the differential housing is in the ID. If the snap ring is out, and the housing metal has not been, forced into the bearing/snapring ID (peaned in), it is still difficult at times to remove the stub shaft in the differential, the stub axle bearing is a press fit into the differential aluminum housing. I agree, a slide hammer or wrap a chain around the “CV” housing with something heavy on the other end, brake drum, brake rotor, and use the chain with weight, as a, do it yourself slide hammer. Try to run your finger around the ID behind the CV, feeling for internal dents. Either way, you could end up using some serious force to get the stub shaft out. I have in the past, used a standard slide hammer with the axle flange adapter on the end and placed the axle flange adapter behind the stub shaft, hammering until I can hammer no more! Once the stub shaft and bearing are out, consider filing the area smooth of dents in the ID.
Good Luck, Steve Vukobratovich
The circlip was still in place at the end of the driveshaft when I removed it. I have since removed it and am now wondering how to get the inner joint off the shaft. I’ve read that you need to hit the inner race, but just wondering how hard. Again, don’t want to damage anything. Not sure what a slide hammer is and how to use one, but I will tomorrow! Thanks. Dan
Sounds like a 3 jaw or 3 legged puller might be a more gentle solution for removing the outer race from the differential and the inner race from the driveshaft. Hope I’m using the correct terminology. Thanks. Dan
Well, heck, if the circlip is removed, go ahead and remove the stub axle with the joint and work on it on the bench, unless diff is already out of the car and on the bench. A slide hammer will either pull the axle out or pull the joint off. Try to get some heat on the aluminum case(at the bearing point) to expand it, then pull.
Greg Z
Well, a couple of new tools later (slide hammer and 3 leg puller) and I am still no closer to getting the the joint off. I’ve actually given up on the ideas of trying to get the joint off (not enough of a gap to get the 3 leg puller on it). I have now removed the inner circlip and am attempting to pull the stub shaft and joint out as one piece. I have a chain wrapped around the whole thing and have tried using the slide hammer, but no joy. A friend has volunteered his heat gun, how would I use it to get the stub shaft out? Open to any and all suggestions. Thanks. Dan
The Cv joint will be spigoted into a recess in the diff output shaft. This should only a a light push fit and it should come out easily. It looks like the fit is to tight and or it has rusted solid in their.
I would try the following
Gently heat the diff output shaft flange to around 100C and chill the CV joint with loctite freeze and release spray. Gently tap on the sides of the cv joint with a soft hammer, not to hard or you risk damaging the diff output bearing. This should split the the cv joint from the diff output shaft
If the above does not work after a couple of tries then 2 choices. Sacrifice the cv joint by grinding some slots in it and using the 3 leg puller to get off the diff output shaft or remove the diff output shaft and cv joint complete and work on the bench to spearate where you can be more brutal in how heat the shaft and freeze and hit the cv joint
Dan,
have you taken the other side off? This should confirm how the joint is fixed in place before you use heat/brute force and may avoid you damaging the diff casing.
I haven’t taken the other side off, as only this side had a torn cv boot. According to a mechanic that has worked on the car since the early 80’s, these cv driveshafts have been on since the 70’s. So I suspect its rusted in there. Dan
Not sure what releasing agents you’ve tried but Plus Gas is very good
Whoever put this thing on was crazy for loctite. Most of the threads on the 12 bolts I removed where still packed full of it. He also painted the whole unit to additionally seal everything together.
I like Rohan’s idea of heating the diff output shaft flange and freezing the joint, and just leaving well enough alone with the stub shaft. If that fails, then I will try penetrating oil around the stub shaft bearing. Then, could I heat the diff to 100C and spray lotite freeze and release on the bearing and then try the slide hammer on it?
Also, what does 100C feel like to the touch? How do I know I’m at 100C? Thanks all. “Down, but not done” Dan
Well for a start, it’s too hot to touch - it’s boiling point after all. If you can touch it, it’s not hot enough. When a drop of water on the surface just starts to boil off, that’s about right.
How do you plan to heat it up? The mechanic’s tool would be oxy-acetylene but this could easily damage the ally housing.
I tend to start with a more gentle heat e.g. an electric hot air gun (which may not have enough power for such a large chunk of metal) and then move on to a propane torch played carefully over the surface.
A friend that was an aircraft mechanic has a hot air gun, I was planning to invite him and his gun over. When I talked to him about my problem this weekend, it sounded like heating to separate is a common practice in that field. Thanks. Dan
If the Cv joint has been assembled into the spigot on the diff output shaft with loctite depending on the grade used it may take some removing.
The heat and chill may work but it may not. You can always release the loctite by heating to around 300C to melt it but you need to pull the diff output shaft out from the diff first as this level of heat will risk damage to the alloy diff and ruin the seals and bearings. Pulling the diff output shaft requires removing the circlip in the alloy housing gripping the shaft flange with a suitable puller and then using a slide hammer to pull the shaft with its beaqring out of the diff. Heating the alloy housing around the bearing to around 100C helps the process.
You also asked in an earlier post on removing the inner Cv joint from the shaft after removing the circlip. It should just press off if you have a press. If not support the the inner Cv joint on couple of blocksd of wood and use a drift to drive the shaft off. If your DPO was very keen on loctite he may have used on the slines and you may need to heat to release it.
Thanks Rohan, I was just about to send you a note asking how to remove the inner cv joint. I don’t have a press. I do have a 3 legged puller, but it keeps sliding off the inner race. I may have to go to your Plan B of using a drift. I would assume into the little indent at the end of the driveshaft to drive it off the joint. If I was to use heat to aid this process, where would I apply it?
Thanks. Dan
I’ve done a few minor projects on the car over the last 4 years that I’ve owned it. This is my first major one and its not going very well, but I’m determined and have the winter to get it done. Unfortunately, this is only the first project on the list. Next up; engine mounts, diff mounts & bushings, master brake cylinder & brake seals, ball joints & trunnions. Hopefully, the rest go a bit smoother.
Dan
While I have done all the fitting and removal of bearings and shafts on an Elan with just hammers and drifts and support blocks its a lot easier if you can find access to a press
To get the inner CV off the shaft try the following:
Use a 1/2 inch diameter brass drift on the end of the shaft while supporting the CV joint inner on a couple of wooden blocks. A few swift hammer blows on the drift should remove the CV joint from the shaft.
If it does not move gently heat the CV joint to around 100C, try to just heat the CV and not the shaft, cooling the shaft with loctite freeze and release will also help. Try to drift it off again.
If its not moving still it is probably assembled with loctite also. Heat it up further focusing the heat on the spline area to try to melt the loctite. cool the shaft again with freeze and release and try a couple more time. You can hit it hard with a hammer on the drift without damage
If still unsuccessful find someone with a press to press it off
Pardon my ignorance, but I’ve never seen a CV joint fitting like that - all of the conversions I’m aware of retain the spider and have an adaptor plate that attaches to the spider and to the CV joint. Where did these come from?
Paddy
I’m going to guess that these were made back in the late 70’s, although the basic design seems consistent with contemporary ones. Shaft with inner joint, a cage (not sure the proper term) that loosely fits around inner joint that holds ball bearings in place, outer joint that fits into either flange connected to stub axle or a plate that bolts onto hub (I think, I removed the joint from the plate, not the plate from the hub or whatever it bolts onto).
Using heat will be a trick as the cage is in the way.
Thanks. Dan
