:unsure: I’m going to buy a 1971 Elan Sprint on RHD version. I already spoke to Paul Matty to convert the car in LHD but his quotation, in my opinion, is quite high.
Has anyone been already involved in this experience?
How many and which new parts do I have to buy?
All suggestion will be very appreciate.
Thanks in advance, Luca - Italy
Don’t do it!!
If you want a LHD buy a LHD!
The cars should be keept as they left the factory.
it won’t be the part’s that make it seem expensive it will be the labour figure mr elan 5139 thats a bit out of order me thinks ,how many cars are still out there as they left the factory :huh: not many
you will be telephoning chris neils next having a pop at them saying they should not cut roofs off +2’s
and mick miller for spraying them in 2 pack paint !and spyder for making non origonal parts , if emmapil want’s to buy an elan and convert it he / she should be helped not abused !
Hi all,
Who knows how many left hand drive elans were produced in the various types?
Gino
I have to somewhat agree with Elan5139, but for other reasons. I feel you would be better off finding a left hand drive if that is what you desire. These cars can take enough time and money simply to put right without adding the expense/time to reconfigure. As far a originality, the more the better for me. Chopping off tops is too far. Replacing a defective chassis with a better one is my limit (I kept mine with it’s original chassis tho). Even if you keep a car “Original” much still gets replaced out of necessity even with a run of the mill restoration.
Mike Geiger
66 Elan Coupe’
[b]QUOTE[/b] (emmapil @ Jan 3 2004, 01:14 PM) |
:unsure: :smiley: I'm going to buy a 1971 Elan Sprint on RHD version. I already spoke to Paul Matty to convert the car in LHD but his quotation, in my opinion, is quite high.
Has anyone been already involved in this experience? Well, the most important thing you need is a LHD pedal box - they are rare. And of course a new dashboard. Just my thoughts! Regards |
I’m in the process of doing exactly this. In my case I ended up with a project that had a LHD chassis and a RHD body, so I had to pick one.
The expensive parts you will need are steering rack, pedal assembly and dashboard. You will also have to redo some of the brake plumbing and clutch plumbing, get a longer throttle cable and maybe replace the oil pressure gauge feed. You will also need access to templates or a LHD car to figure out where to drill holes for things in the firewall. And then there’s also all the other things you will find that need to be fixed while everything is apart
I’d also suggest getting a LHD car rather than converting. It’s likely to be cheaper in the long run.
jason
Hi Luca,
I had the same intentions as you to change my Elan to a LHD just after purchasing it and did even ask Mick Miller to quote me the conversion. The price was reasonable but we would have had to discuss the change sometime in 2008 as he was overburdened with restorations that he just didn’t have the time.
I did later meet him and Sue at Saxmundham to discover Elans everywhere in the courtyard waiting for restoration. (Beautiful sight)
I think that if Mick Miller had the time to carry out the conversion immediately I would have probably done it but now I’m glad he didn’t as I can totally agree with Jolly as my elan is also a RHD and in our caotic italian traffic can drive it quite easily and saftely.
Pensaci bene!
Gino
Luca,
If you are going to the trouble of going overseas, or chanel, to get a car, why not go to the States and get one already configured for driving on the wrong side of the road . I believe that they know a few things about maintaining the marque!
Colin.
If you are looking for parts, there is a current listing for usable LHD steering and pedal box parts from a +2 on eBay. Link-
http://cgi.ebay.com/ebaymotors/ws/eBayISAP…item=2452159320
(He is good seller, I bought an S3 Elan from him)
Colin,
It’s not the wrong side of the road!
Most of the world can’t be driving on the wrong side of the road
Gino
GUYS!!! Thanks to everybody for your help. I’m actually more confuse then before!!!
I made a list of what I need and I think (perhaps I will make a mistake), it’s not so complicate. I know the Elan share several steering parts with Triumph Spitfire …or not? I already have a LHD steering rack. I agree about originality but I don’t want ‘federal’ cars, to complicate bring those from US. I already owned a RHD car and actually I didn’t have so much fun on the “wrong” side of the road. Will see; first of all I’ll go to pick up the car and then I will decide.
Thanks again for your help, Luca
Luca,
A little more information for you. On my S3 Coupe’ the body was already drilled for either left or right hand drive. I belive (no firm knowlege) that the dashboard (fascia) are mirror imaged for left/right hand drive. Depending on condition you may be replacing that anyway. As someone ealrier stated, rack (which you have) and pedals will be the difficult parts. Someone on the yahoo list once mentioned that he converted his right hand pedals to left hand. you might want to do a search. At least with left hand drive the brake and clutch master cylinders will be out from under the carbs, thus eaiser to deal with.
Good luck, have fun,
Mike Geiger
Hi Luca,
I was in Luca earlier this year for a weeks holiday. What a great place, medievel walled town, good wine and lovely women to look at (the wife was with me). Maybe someone should organise a rally to see Luca’s project.
As Mike was saying about converting the peddle box. I had my peddle box off and stripped earlier this year. The peddles are made from 1" x 1/4" flat bar and welded to a boss which rides on a shaft across the center of the box. The flat bar (if I remember correctly) is welded to the boss at a slight angle. The bar could be cut off the boss and rewelded at a slight angle in the opposite direction quite easily.
ColinT
dont tony thompsons do a left hand drive pedal box ! i am sure they do worth a call 01664 812454 i think from memory
I did it in the past when I bought one S4SE1969 in the UK and imported it in Belgium. The job was done by myself and this took me some days.
You have to:
- fit another steering rack (I got one from one Triumph Spitfire) but I retained my genuine arms (which are shorter than the ones from the Spit)
- refitted the genuine dashboard (reverse side) but with a new wood cover plate because the opposite side is not polished nor finished
- fitted another mileage counter (in kph instead of mph)
- extention of the genuine wiring (not so easy to do !!!)
- made a “home made one” pedals assembly from an old one coming from the spit and the modification of mine
- some minor modifications (brake fluid / clutch fluid drum assembly; counter cable, …) and new brake/clutch lines
This what I am remembering now because that mod had been made in 1973 (so a long time ago !)
If you need more details, you can contact me.
Edouard de Grand Ry
avenue Marie Th?r?se, 7
1410 Waterloo/Belgium
E mail: [email protected]
Proper cars should be RHD - show me a LHD Bugatti, pre-war Alfa, etc. etc. Enough said.
I totally agree with you and my next Elan will be (and remain) RHD ! Definitely and enough said ! I regret the transformation I made on my S4Se because it has lost a part of its genuine atmosfere and the fantastic cars agility allow any driver to move safely on right side driving roads as we have in Belgium.
Edouard de Grand Ry
avenue Marie Th?r?se 7
Hi there
I just want to add, that I think it was easy to convert my SE4SE to LHD.
My wiring loom was not extended - just bent over - the wires were long enough.
The pedal box was taken apart and just welded together different in a few places and the mounting for the box is already in the caras were the holes for the master cylinders.
Only major problem I see could be a KM speedo. I had one but with a wrong “ratio” inside, so why not just use the MPH one.
Steffen
Denmark
Ye who owns it owns it, and who knows, maybe the next guy or girl to own some converted Lotus will put it back the other way? Could be temporary. Not like ruining one completely by turning it into a racing car or something unfactorylike. I’m in the USA, checked the backs of my dashboards and I think my cars left the factory with LHD, what is proper for me? It’s fun to communicate with people who mention Elans, Bugattis and pre war Alfas all in one sentence. This topic seems to be stirring a pot… (and I’d like to add, may God Bless all the Italians driving RHD Elans in Italy! I can not even imagine…)
