Johan…There are 3 main things that are expensive to fix on any Elan, and in order they are bodywork / paint, engine and chassis. The chassis is a lot cheaper to fix than a tired engine, and together they will cost less that rough paintwork to sort out. So I wouldn’t be to bothered about an original chassis, unless you are after a perfect, fully restored car.
There are only really 2 areas of the chassis you can inspect; the front towers that support the front wishbones, and the engine mounting points. It’s the front towers which rust out, or are bent due to clipping a kerb. You can perform a reasonable inspection of them with a screwdriver (if the owner doesn’t mind!) to detect any serious rot. You really need to jack the car up, using the front member of the chassis (which doubles up as the vacuum tank). If you find some rot, the car shouldn’t really be driven. The other tell-tale with rusted towers is that the vacuum tank, which powers the headlights, will not hold a vacuum. Without the engine running, if the headlights don’t stay down when off (on a late Plus 2) or up when on (early car) then a cause could be the chassis tank,but there are other causes as well.
Even if you don’t find rot, there may well be stress cracks around the towers, which are much more difficult to see without cleaning the whole area off.
The stress cracks that can occour around the engine mountings are much more obvious, and can usually be seen from under the bonnet.
If you want a fully restored car, and the one you look at is fine apart from the chassis, it is still worth buying at the right price. Putting a new chassis on an Elan is a pretty straightforward job, and it allows you to overhaul the rest of the mechanical bits with ease…compared to trying to fix things with the body in place, and rusty nuts and bolts that haven’t been touched in many years.
If the car still has it’s original chassis, and it has been driven regularly over the past few years, chances are it will do a few more. If it hasn’t been used for a long time, expect to replace it,
As an indication, Paul Matty charges about 50 hours work to change a chassis. A lot less than restoring a rusty Healey, MGB or E Type!
As for original and matching numbers, that rule doesn’t seem to apply to Elans. Most folks, like you, want a non-original new chassis. I don’t even think that a matching engine number makes a huge, if any, difference
