Carpet Underfelt
Hi All
I’m about to fit new carpets in my +2. The question I have is should I fit new traditional underfelt or should I use the newer high density foam type of underfelt. Is there any difference on the sound deadening effect of the two types?
The thoughts I have on it are the the foam is lighter and less prone to absorb water. Anyone experience or thoughts gratefully received.
Andy
under advisement from a specialist, I’m going to use the trad type, apparently the sound deadening qualities are superior
regards
Does anyone know of a spray on fire proof product that is sound deadening and spongy?
the only fire proof spray on “foam” I can think of is the stuff they use to protect the steel work in high rise buildings. What are you trying to do?
Look at this site.
quietcoat.com/
David
1968 36/7988
