Car got through its MOT after a 12 month layup having the engine rebuilt…
Slight fly in the ointment though.
Clutch hydraulics seem reluctant to bleed (new slave and master)
Is the bleed nipple above the pipe.
yep.
Will have another go when I am not rushing…
A good way to remove stubborn air is to flow in reverse
Make sure you have some spare level in your master cylinder and then get someone to watch inside it while you ( or even better if you can persuade the other person to grovel out underneath while you watch the master cylinder
) go underneath with an oil can full of the required brake /clutch fluid.
fix a bit of suitable pipe the the oil can and pump up fluid to fill this then connect the open end to the slave cylinder bleed nipple, open the bleed screw and pump the oil can.
This forces fluid back into the slave cylinder and any air “SHOULD” by the laws of physics be expelled from the top of this cylinder up through the connecting pipe and bubble out through the master cylinder reservoir,
Just make sure the master cylinder doesn’t overflow and strip paint off anything
This method I have found to be really useful on many cars when they are proving difficult to bleed either Clutch or brakes I have done both.
PS: on a happier note I changed my slave cylinder seals last year and 2 pumps of the peddle and all was perfect as described somewhere in another thread. I was accused of having the ‘luck of the Irish’ even though I’m and englishman living there
