Can anyone identify this item?
Clearing up I came across this rod wrapped in anti-rust paper and looking automotive.
Main diameter 3/8" (9.6 mm)
Spigot diameter 19/64" (7.7 mm)
Main length to shoulder 3 1/64" (76.5 mm)
Spigot length 15/16" (23.6 mm)
Both ends are chamfered but the shoulder is square.
Clutch alignment tool?
Drift ?
John :wink:
Valve guide remover/replacer drift.
+1 but not sure it fits the twin cam guide dimensions
+1 drift Valve Guides
No problem, you just need to hit it a bit harder and a few times more. :wink:
I am overwhelmed by your response and it surely is a valve guide drift, the dimensions are perfect as guide bore in head is 0.500". I don’t remember buying it so it must have been a long time ago; does anyone want it?
Thanks all!
Is the small size 5/16"?
If it is 5/16" and still available I would like it please. If so please let me know how much you want for it (and post) and I’ll send some money over to you.
Cheers.
Al
[quote=“promotor”
Cheers.
Al[/quote]
Yup, 1/64" under it and as you sent me a couple of camshaft dowels free in 2017 I’ll do the same for you!
PM your address and it’s a deal!
Ok will do, thanks very much! I’d forgotten about the dowels, in fact I don’t remember it at all! :slight_smile:
