BM - Body - Interior +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
1 050B6029 2 Door Seal - Primary
2 050B0630 2 Door Seal - Secondary
050B1821 1 Door Seal
050B1822 1 Door Seal
050B6003 10 Rivet
3 050B1174 2 Front Seat Assembly West Germany upto 1906
B050B0739 1 Front Seat Assembly LH, West Germany only, Anti-tilt without headrest. From 1907 to ?
B050B0740 1 Front Seat Assembly RH, West Germany only, Anti-tilt without headrest. From 1907 to ?
A050B1906 1 Front Seat Assembly LH, West Germany only, Anti-tilt without headrest. From ?
A050B1907 1 Front Seat Assembly RH, West Germany only, Anti-tilt without headrest. From ?
A050B1174 - Front Seat Assembly (replaced by A050B0739 LH
A050B0740 RH)
4 050B0739 1 1 Front Seat Assembly LH
A050B0740 1 1 Front Seat Assembly RH
5 050B6057 1 Seat Runner Assembly LH Upto ?
050B6131 - Seat Runner Assembly (replaced by A050B1523)
A050B1523 1 Seat Runner Assembly LH From ?
6 050B6058 1 1 Seat Runner Assembly RH Upto ?
050B6132 - Seat Runner Assembly (replaced by A050B1524)
A050B1524 1 Seat Runner Assembly RH From ?
7 XUFB0424 4 Bolt, Seat to Runner
8 A04W0905 4 Washer, Seat to Runner
9 LUFN040F 4 Nut, Seat to Runner
10 XUCS0416 8 Screw, Runner to Body
11 A04W0904 8 Washer, Runner to Body
A04W1606 16 Washer, Runner to Body
12 050B0835 1 1 Rear Parcel Shelf Assembly
A050B0835 1 1 1 Rear Parcel Shelf Assembly
13 050B1337 1 1 Angle - Rear Parcel Shelf
050B1548 1 1 1 Angle - Rear Parcel Shelf
A036B0540 7 Clip - Shelf Support
KSTS0608 2 Screw
Cupwasher
050B6121 AR Rivet - Angle to Board
14 050B2003 1 1 Rear Seat Squab
15 050B1228 1 1 Centre Panel - Rear Seat
A050B2028 8 Clip, Centre Panel to Seat Back
036B6007 8 Snapsac, Centre Panel to Seat Back
16 050B2011 1 1 Rear Seat Cushion Assembly LH
17 050B2012 1 1 Rear Seat Cushion Assembly RH
050B1238 4 Bracket - Rear Seat Cushion Retaining
050B6003 8 Rivet - Bracket to Cushion Board
PSTS0412 2 Screw, Bracket to Body
PSTS0620 4 Screw - Black, Bracket to Body
18 A050B2017 1 Rear Quarter Panel Assembly LH
B050B2017 1 Rear Quarter Panel Assembly LH
19 A050B2018 1 Rear Quarter Panel Assembly RH
B050B2018 1 Rear Quarter Panel Assembly RH
KSTS0612 4 Screw - Panel to Door Flange
20 050B2023 1 1 Insert - Rear Quarter Door LH
21 050B2024 1 1 Insert - Rear Quarter Door RH
A050B2028 14 Clip, Insert to Quarter Panel
036B6007 14 Snapsac, Insert to Quarter Panel
050B1355 2 2 Angle - Quarter Panel Mounting
036B1656 16 Rivet - Angle to g.f.r.p.
050B2026 2 2 Retaining Strip - Rear Quarter Upper Trim
050B6003 AR AR Rivet, Retaining Strip to Rear Quarter Trim Panel
A02W0405 2 2 Washer, Retaining Strip to Rear Quarter Trim Panel
050B6059 2 2 2 Coat Hook
050B1537 2 2 Coat Hook
050B6060 2 2 Clip - Coat Hook
050B6061 2 2 Screw, Coat Hook Mounting Upto ?
050B6062 2 2 Nut, Coat Hook Mounting Upto ?
PBAS0416 2 2 Screw, Coat Hook Mounting
BAN000H 2 2 Nut, Coat Hook Mounting
L03W0000 4 4 Washer, Coat Hook Mounting
050B1545 1 1 1 Spacer - Coat Hook
A05W1206 2 2 2 Washer (Chrome) - Coat Hook
AUCN040H 2 2 2 Lock Nut - Coat Hook
A05W1206 2 2 2 Washer - Coat Hook
050B1638 2 2 2 Badge - Coat Hook
23 050B0243 1 1 Tunnel Top
050B1275 1 Mounting Plate Magnetic Catch
24 050B0811 1 Arm Rest Assembly - Tunnel top
25 050B6050 1 Hinge - Tunnel Arm Rest
050B6054 1 Catchpalte Upto ?
050B6053 1 magnetic Catch Upto ?
050B6055 2 Rivet - Plate to Arm Rest
3 Flat Nut - Hinge to Royalite
2 Flat Nut - Catch to Mounting Plate
2 Screw - Catch to Mounting Plate
3 Screw - Hinge to Royalite
3 Screw - Hinge to Lid
1 Magnetic Catch From ?
1 Catch Plate From ?
26 050B0839 2 Sun Visor Upto 0928
050B0839 1 1 Sun Visor - without mirror (Driver’s Side) From 0929
A050N0839 1 1 + Sun Visor - without mirror (Driver’s Side)
050N0840 1 1 Sun Visor - without mirror (Passenger Side) From 0929
A050N0840 1 1 + Sun Visor - without mirror (Driver’s Side)
A050B0863 1 1 + Sun Visor - with mirror (Passenger Side)
A050B0864 1 1 Sun Visor - without mirror (Driver’s Side)
27 050B1276 1 Bracket - Sun Visor LH
28 050B1277 1 Bracket - Sun Visor RH
KSTS1008 4 Screw - Sun Visor to Body
050B6056 1 Interior Rear View Mirror (Fixed)
050B0564 1 Interior Rear View Mirror (Dipping)
29 036B6031 1 Interior Rear View Mirror Upto ?
30 DSTS0808 1 Screw, Mirror Fixing Upto ?
31 DSTS0408 2 Screw, Mirror Fixing Upto ?
32 DSTS0608 1 Screw, Mirror Fixing Upto ?
050B1564 1 Interior Rear View Morror From ?
33 050B1360 1 1 Headlining Trim (replaced by 050B0360A)
050B0360A 1 1 Headlining Trim
A050B0360 1 1 1 Headlining Trim
34 050B0509 4 Tube, Listing - Headlining
35 036B0538 8 Peg Tube
36 036B6001 8 Nut
37 315A 8 Screw
40 050B0230 1 Crash Pad
41 050M6023 2 Radio Speaker Bezel
42 050B1197 1 Boot Floor LH Upto 0928
A050B1197 1 Boot Floor LH From 0929
43 050B0098 1 Boot Floor RH Upto 0928
A050B1198 1 Boot Floor RH From 0929
050B1238 4 Bracket - Boot Floor Mounting
MSTS0608 8 Screw - Boot Floor Mounting
44 050B6049 2 Grille - Demist vent
45 PSTS0608 4 Screw - Grille to Crash Pad
