does anyone recognize this ignition key?
I need a second set of keys but cannot find the correct blanks.
The car in question is a 1972 Elan Sprint with the ignition switch on the steering column rather than the dashboard. The car is original spec throughout.
We tried the Ilco blank mentioned here, but it is different. Any ideas?
The key is the same as the ones I have had for both my plus 2’s. I believe they are the original design.
I got a new blank of the same design from a guy at the NEC Classic Car Show. Cost me a fiver. I think he was called The Key Man, or something like that. Anyway he said that he doesn’t sell online - just does a couple of shows a year. You’ll have to look out for him.
edit - Sorry, just noticed you are in Germany. Maybe worth a visit to this years UK classic car show…?
My 1973 Sprint had an ignition key like the one in the photo. My local locksmith here in Dublin had blanks in stock six months ago, but without the plastic. It must an easily available key type. Unfortunately I no longer have the car and so cannot identfy the key type code.
Try UK suppliers. Sue Miller is a good place to start as already suggested.
The key looks similar to my Sprint ignition key.
When I had a duplicate cut the guy did not have the correct looking key so just cut in onto a smaller headed one.
Works fine.
Have a look at www.key-men.com ,based in the US, DM1RAP looks similar to your key, unfortunately out of stock but alternate manufacturers part numbers are listed.
I used key-men with great results. I had removed the lock and sent them the code on it and they cut perfect new keys. The keys that came car were so badly worn I could not get good copies made.
For info - I’ve just found that an early 70s Jaguar key blank DM1R works fine for my '73 +2S with a steering column lock. In stock at and cut by guardwell.com/ (Blackwater, Surrey) who were extremely helpful.
