BL - Body - Headlamp Vacuum System
Item Lotus # All S1 S2 S3 S3 SS S4 S4FED SPRINT RHD LHD Description Change Point
Notes
Bulletin Reference
1 026B0119 1 1 1 1 1 Headlamp Bowl, LH Non-Failsafe
2 026B0120 1 1 1 1 1 Headlamp Bowl, RH Non-Failsafe
XUCS0420 2 2 2 2 2 Screw Non-Failsafe
3 026B0119A 1 Headlamp Bowl, LH 1970 Fedaral Failsafe
4 026B0120A 1 Headlamp Bowl, RH 1970 Fedaral Failsafe
XUCS0432 2 Screw 1970 Fedaral Failsafe
L04W0000 2 Washer 1970 Fedaral Failsafe
5 026B0123 1 1 1 1 1 Vacuum Cylinder, LH Non-Failsafe
6 026B0124 1 1 1 1 1 Vacuum Cylinder, RH Non-Failsafe
XUFS0412 2 2 2 2 2 Screw, Cylinders to Body Non-Failsafe
YUFN040F 4 4 4 4 4 Nut, Cylinders to Body Non-Failsafe
A04W0904 2 2 2 2 2 Washer, Cylinders to Body Non-Failsafe
A04W1606 2 2 2 2 2 Washer, Cylinders to Body Non-Failsafe
7 036B1664 1 Vacuum Cylinder 1970 Fedaral Failsafe
LUFN 040F 1 Nut, Cylinder to Bracket 1970 Fedaral Failsafe
A04W0904 1 Washer, Cylinder to Bracket 1970 Fedaral Failsafe
8 036B1829 2 2 2 2 2 Bracket, Vacuum Cylinder Non-Failsafe
XUFS0408 4 4 4 4 4 Screw, Bracket to Body Non-Failsafe
LUFN040F 4 4 4 4 4 Nut, Bracket to Body Non-Failsafe
A04W1606 4 4 4 4 4 Washer, Bracket to Body Non-Failsafe
9 036B1315 1 Bracket, Vacuum Cylinder 1970 Fedaral Failsafe
XUFS0408 3 Screw, Bracket to Body 1970 Fedaral Failsafe
LUFN040F 3 Nut, Bracket to Body 1970 Fedaral Failsafe
A04W1606 3 Washer, Bracket to Body 1970 Fedaral Failsafe
10 026B0117 1 1 1 1 1 Spring, Headlamp Return, LH Non-Failsafe
11 026B0118 1 1 1 1 1 Spring, Headlamp Return, RH Non-Failsafe
12 XUFB0420 2 2 2 2 2 Bolt, Return Spring to Headlamp Non-Failsafe
13 026B0122 2 2 2 2 2 Distance Tube, Return Spring to Headlamp Non-Failsafe
14 A04W0904 2 2 2 2 2 Washer, Return Spring to Headlamp Non-Failsafe
15 A06W1207 6 6 6 6 6 Washer, Return Spring to Headlamp Non-Failsafe
16 YUFN080P 2 2 2 2 2 Nut, Return Spring to Headlamp Non-Failsafe
17 026B0388 1 1 1 1 1 Spring, Headlamp Valve Non-Failsafe
18 036B0118 1 Spring, Headlamp Return
19 XUFS0416 1 Screw, Return Spring
20 A05W1007 4 Washer, Return Spring
L05W0000 4 Washer, Return Spring
21 YUFN050F 1 Nut, Return Spring
22 036B1658 1 Rod, Operating
23 036B6154 4 Joint, Anti Rattle
24 A036B1657 2 Link, Threaded
25 026B0736 1 1 1 1 1 Valve, Headlamp Operating Non-Failsafe
26 A026B0736 1 Valve, Headlamp Operating 1970 Federal Failsafe
27 036B6008 1 Knob, Valve
026B0039 1 Bezel, Valve
026B0129 1 1 1 1 1 ‘T’ Piece Upto 8729
026B0125 1 1 1 1 1 Adaptor Upto 8729
026B0136 1 1 1 1 1 Non-Return Valve Upto 8729
28 J0019 1 1 ‘T’ Piece From 8730
29 036B0136 1 1 Non-Return Valve From 8730
036M6266 2 2 2 2 2 Micro Switch Non-Failsafe
J0017 1 1 1 1 1 Sleeve Non-Failsafe
026B0387 1 1 1 1 1 Pipe, Headlamp Valve Non-Failsafe
30 050M0124 2 Micro Switch 1970 Federal Failsaf
036J0135 1 Elbow, Switch 1970 Federal Failsaf
036B1675 1 Mounting Plate, Switch 1970 Federal Failsaf
036B1676 1 Operatlng Shoe, Switch 1970 Federal Failsaf
036M0777 1 Loom, Switch 1970 Federal Failsaf
036B6010 1 Grommet, Loom 1970 Federal Failsaf
31 026B0131 1 1 1 1 1 + Pipe, 64 ins. long
32 026B0132 1 1 1 1 1 + Pipe, 61 ins. long
33 036B0381 1 Pipe, 57 ins. long
34 036B0380 1 Pipe, 55 ins. long
35 026B0133 1 1 1 1 1 Pipe, 24 ins. long
36 026B0130 1 Pipe, 23 ins. long
37 J0017 8 8 8 8 5 3 Sleeve
036B6009 1 ‘P’ Clip, Pipes to Body
036B6026 1 Spire Screw, Pipes to Body
036B6001 1 Spire Nut, Pipes to Body
036B6010 2 Grommet, Pipes to Scuttle
036B6011 AR Tape, Pipes Mounting
