BHF - Body - Instruments Mid +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
1 050B6079 1 Speedometer
2 036B6075 1 Trip Reset Cable
036B6107 1 Cable - Speedometer Drive
036B6010 1 Grommet - Speedometer Drive Cable
3 050B6081 1 Tachometer Upto 1086 also installed in 1089, 1090, 1093, 1095 & 1098
036M6102 1 Tachometer From 1087 also installed in 0963-67, 0973, 9081, 1067, 1076 & 1079
4 050B6082 1 Gauge - Water Temperature
5 050B6084 1 Gauge - Oil Pressure
050B6085 1 Switch - Oil Pressure
6 050B6086 1 Gauge - Fuel
7 046B6008 1 Gauge - Ammeter Upto ?
050B6087 1 Gauge - Ammeter From ?
8 036M6097 2 2 Switch - Window Operating
9 050M6073 1 Switch - Panel/Interior Lamp
10 036M6095 1 Switch - Fan Heater
11 1 Switch - Screen Wash
12 036M6153 1 Switch - Screen Wiper
13 050B6084 1 Switch - Sidelamps
14 050M6074 1 Switch - Hazard Warning
050M6091 1 Switch - Hazard Warning From 2526
15 036M6094 1 Switch - Rear Screen
16 036M6031 1 Cigar Lighter
17 036M6032 1 Cigar Lighter Knob
A036M6382 1 Bulb (12v. 2.2w)
18 A026B0736 1 Valve - Headlamp Operatlng
19 036B6008 1 Knob - Headlamp Operating Valve
20 036B6015 1 Ignition Switch
036M6144 1 Locking Cylinder
036B6016 AR Washer - Switch Mounting
036B0314 1 Lock Plate - Switceh Mounting
21 036M6l45 1 Indicator Lamp - Hazard Warning
22 036M6030 1 Indlcator Lamp - Parking Brake
23 050M6076 1 Indicator Lamp - Brake Fail
24 050M6075 1 Indicator Lamp - Rear Screen
25 A050B0101 1 Choke Cable
A050M6188 AR Bulb - Indicator Lamps and Instruments
050M6157 AR Bulb - Ashtray Illumination
