Item | Lotus # | All | S1 | S2 | S3 | S3 SS | S4 | S4FED | SPRINT | RHD | LHD | Description | Change Point Notes Bulletin Reference |
036B0707 | 1 | 1 | 1 | 1 | Door Assembly, LH | From 5811 | |||||||
036B0708 | 1 | 1 | 1 | 1 | Door Assembly, RH | From 5811 | |||||||
036B0755 | 1 | 1 | Door Shell, LH | From 5811 Upto 7894 | |||||||||
036B0756 | 1 | 1 | Door Shell, RH | From 5811 Upto 7894 | |||||||||
1 | A036B0755 | 1 | 1 | Door Shell, LH | From 7895 | ||||||||
A036B0756 | 1 | 1 | Door Shell, RH | From 7895 | |||||||||
026B0072 | 4 | 4 | Door Hinge Arm | From 5811 Upto 7894 | |||||||||
2 | A026B0072 | 4 | 4 | Door Hinge Arm | From 7895 | ||||||||
026B0073 | 4 | 4 | Door Hinge Pin | From 5811 Upto 7894 | |||||||||
3 | A026B0073 | 4 | 4 | Door Hinge Pin | From 7895 | ||||||||
4 | 026B0069 | 4 | 4 | 4 | 4 | Locking Bolt, Hinge | From 5811 | ||||||
XUCB0524 | 2 | 2 | 2 | 2 | Bolt, Lower Door Hinge Arms | From 5811 | |||||||
XUCB0520 | 2 | 2 | 2 | 2 | Bolt, Lower Door Hinge Arms | From 5811 | |||||||
L05W0000 | 4 | 4 | 4 | 4 | Washer, Lower Door Hinge Arms | From 5811 | |||||||
026B0079 | 2 | 2 | 2 | 20 | Washer, Lower Door Hinge Arms | From 5811 | |||||||
026B0103 | 6 | 6 | 6 | 6 | Washer, Lower Door Hinge Arms | From 5811 | |||||||
XUCB0524 | 2 | 2 | 2 | 2 | Bolt, Upper Door Hinge Arms and Door Check | From 5811 | |||||||
XUCB0520 | 2 | 2 | 2 | 20 | Bolt, Upper Door Hinge Arms and Door Check | From 5811 | |||||||
L05W0000 | 4 | 4 | 4 | 4 | Washer, Upper Door Hinge Arms and Door Check | From 5811 | |||||||
036B0837 | 1 | 1 | 1 | 1 | Door Check Installatlon, LH | From 5811 | |||||||
036B0838 | 1 | 1 | 1 | 1 | Door Check Installatlon, RH | From 5811 | |||||||
5 | 036B0801 | 2 | 2 | 2 | 2 | Backplate Assembly, Door Check | From 5811 | ||||||
036B0491 | 2 | 2 | 2 | 2 | Backplate | From 5811 | |||||||
036B0490 | 2 | 2 | 2 | 2 | Clip | From 5811 | |||||||
6 | 036B0492 | 2 | 2 | 2 | 2 | Buffer, Door Check | From 5811 | ||||||
XUFS1016 | 4 | 4 | 4 | 4 | Screw, Backplate and Buffer to Body | From 5811 | |||||||
A03W0605 | 8 | 8 | 8 | 8 | Washer, Backplate and Buffer to Body | From 5811 | |||||||
AUFN100F | 4 | 4 | 4 | 4 | Nut, Backplate and Buffer to Body | From 5811 | |||||||
7 | A036B0489 | 2 | 2 | 2 | 2 | Tube, Door Check | From 5811 | ||||||
A04W0905 | 2 | 2 | 2 | 2 | Washer, Tube | From 5811 | |||||||
036B6180 | 2 | 2 | 2 | 2 | Clip, Tube | From 5811 | |||||||
8 | 036B0819 | 1 | 1 | 1 | 1 | Hinge Plate Assembly, LH | From 5811 | ||||||
036B0820 | 1 | 1 | 1 | 1 | Hinge Plate Assembly, RH | From 5811 | |||||||
036B0721A | 1 | Door Trim Panel, LH | From 5811 Upto 7399 | ||||||||||
036B0722A | 1 | Door Trim Panel, RH | From 5811 Upto 7399 | ||||||||||
9 | A036B0721A | 1 | Door Trim Panel, LH | From 7400 Upto 7894 | |||||||||
A036B0722A | 1 | Door Trim Panel, RH | From 7400 Upto 7894 | ||||||||||
B036B0721A | 1 | 1 | Door Trim Panel, LH | From 7895 | |||||||||
B036B0722A | 1 | 1 | Door Trim Panel, RH | From 7895 | |||||||||
036B0719A | 1 | Door Trim Assembly, LH | From 5811 Upto 7399 | ||||||||||
036B0720A | 1 | Door Trim Assembly, RH | From 5811 Upto 7399 | ||||||||||
10 | A036B0719A | 1 | Door Trim Assembly, LH | From 7400 Upto 7894 | |||||||||
A036B0720A | 1 | Door Trim Assembly, RH | From 7400 Upto 7894 | ||||||||||
11 | A036B0426 | 2 | 2 | 2 | 2 | Foam, Trim Panel | From 5811 | ||||||
12 | A050B2028 | 16 | 16 | 16 | 16 | Clip, Trim to Door | From 5811 | ||||||
13 | 036B6007 | 16 | 16 | 16 | 16 | Snapsac, Clip | From 5811 | ||||||
14 | 036B6038 | 2 | 2 | 2 | Door Pull Handle | From 7400 | |||||||
DUFS1008 | 4 | 4 | 4 | Screw, Door Pull | From 7400 | ||||||||
A03W1606 | 4 | 4 | 4 | Washer, Door Pull | From 7400 | ||||||||
LUFN100F | 4 | 4 | 4 | Nut, Door Pull | From 7400 |
