Item | Lotus # | All | S1 | S2 | S3 | S3 SS | S4 | S4FED | SPRINT | RHD | LHD | Description | Change Point Notes Bulletin Reference |
026B0230 | 1 | 1 | Crash Pad | Upto 5810 | |||||||||
1 | 036B0230 | 1 | Crash Pad | From 5811 to 7399 | |||||||||
2 | A036B0230 | 1 | 1 | 1 | Crash Pad | From 7400 | |||||||
KSTS0616 | 2 | Screw, Crash Pad to Body | |||||||||||
036B6002 | 2 | Spire Nut, Crash Pad to Body | |||||||||||
3 | 026B0627 | 1 | 1 | 1 | 1 | 1 | 1 | Grille | Upto 8767 | ||||
026B0048 | 1 | 1 | 1 | 1 | 1 | 1 | Support, Rear | Upto 8767 | |||||
026B0051 | 1 | 1 | Support, Centre | Upto 8767 | |||||||||
026B0052 | 1 | 1 | Support, Outer | Upto 8767 | |||||||||
RUFS0624 | 2 | 2 | 4 | 4 | 4 | 4 | Screw | Upto 8767 | |||||
RUFS0620 | 2 | 2 | 2 | 2 | 2 | 2 | Screw | Upto 8767 | |||||
LUFN060P | 4 | 4 | 4 | 4 | 4 | 4 | Nut | Upto 8767 | |||||
026B6055 | 6 | 6 | 6 | 6 | 6 | 6 | Trim Cap | Upto 8767 | |||||
4 | 050B6049 | 2 | 2 | Vent Grille | From 8768 | ||||||||
RSTS0616 | 2 | 2 | Screw | From 8768 | |||||||||
036B6002 | 2 | 2 | Spire Nut | From 8768 | |||||||||
026B0477 | 1 | 1 | Trim, Windscreen Pillar, LH | Upto 5810 | |||||||||
026B0478 | 1 | 1 | Trim, Windscreen Pillar, RH | Upto 5810 | |||||||||
5 | 036B0477 | 1 | 1 | Trim, Windscreen Pillar, LH | From 5811 Upto 7894 | ||||||||
6 | 036B0478 | 1 | 1 | Trim, Windscreen Pillar, RH | From 5811 Upto 7894 | ||||||||
7 | A036B0477 | 1 | 1 | Trim, Windscreen Pillar, LH | From 7895 | ||||||||
8 | A036B0478 | 1 | 1 | Trim, Windscreen Pillar, RH | From 7895 | ||||||||
9 | 500B0268 | 1 | 1 | 1 | 1 | Trim, Header Rail (Convertible) | From 5811 | ||||||
10 | 036B0839 | 1 | 1 | Sun Visor, LH | From 5811 | ||||||||
11 | 036B0840 | 1 | 1 | 1 | 1 | Sun Visor, RH | From 5811 | ||||||
036B0839A | 1 | 1 | Sun Visor, LH | From 7400 to 7894 | |||||||||
045B0839 | 1 | Sun Visor, LH (Convertible) | From 7895 | ||||||||||
DSTS1008 | 4 | Screw, Sun Visor | |||||||||||
026B6056 | 1 | 1 | Interior Driving Mirror (Std.) | ||||||||||
026B6057 | 1 | Interior Driving Mirror (S/E) | |||||||||||
036B6056 | 1 | 1 | Interior Driving Mirror | From 5811 to 7894 | |||||||||
12 | 046B6039 | 1 | Interior Driving Mirror (Coupe) | From 7895 | |||||||||
500B1028 | 1 | Interior Driving Mirror (Convertible) | From 7895 | ||||||||||
036B6099 | 1 | Interior Driving Mirror (Coupe) | From 7895 | ||||||||||
036B6297 | 1 | Interior Driving Mirror (Convertible) | From 7895 | ||||||||||
DSTS 0408 | 4 | Screw, Mirror | |||||||||||
036B0360 | 1 | 1 | Headlining, Coupe only | From 5811 to 7894 | |||||||||
13 | 036B0360A | 1 | 1 | Headlining, Coupe only | From 7895 | ||||||||
14 | 036B0509 | 3 | 3 | 3 | 3 | Listing Tube, Coupe only | From 7895 | ||||||
036B0538 | 6 | 6 | 6 | 6 | Peg | From 5811 | |||||||
KSTS0612 | 6 | 6 | 6 | 6 | Screw | From 5811 | |||||||
036B6001 | 6 | 6 | 6 | 6 | Nut | From 5811 | |||||||
A036B0567 | 1 | 1 | Trim Panel, Rear Quarter, LH | From 5811 | |||||||||
A036B0568 | 1 | 1 | Trim Panel, Rear Quarter, LH | From 5811 | |||||||||
15 | B036B0777 | 1 | 1 | Trim Panel, Rear Quarter, LH | From 7895 Coupe | ||||||||
16 | B036B0778 | 1 | 1 | Trim Panel, Rear Quarter, LH | From 7895 Coupe | ||||||||
036B6298 | 4 | 4 | 4 | 4 | Clip | From 5811 | |||||||
036B6007 | 4 | 4 | 4 | 4 | Snapsac | From 5811 | |||||||
026B0320 | 2 | 2 | Door Seal | Upto 5810 | |||||||||
026B0321 | 2 | 2 | Sealing Rubber | Upto 5810 | |||||||||
026B0323 | 2 | 2 | Weatherseal and Stop | Upto 5810 | |||||||||
026B0324 | 2 | 2 | Weatherseal Block | Upto 5810 | |||||||||
026B0325 | 2 | 2 | Door Seal | Upto 5810 | |||||||||
17 | 036B0320 | 2 | 2 | 2 | 2 | Door Seal, Coupe | From 5811 | ||||||
045B0320 | 2 | 2 | 2 | 2 | Door Seal, Convertible | From 5811 | |||||||
036B6000 | 2 | 2 | 2 | 2 | Secoudary Seal, Door | From 5811 | |||||||
036B2002 | 2 | 2 | 2 | 2 | Strip, Retainlng | From 5811 | |||||||
433AA | 10 | 10 | 10 | 10 | ‘Pop’ Rivet | From 5811 | |||||||
026B0749 | 1 | 1 | Boot Floor Assembly | Upto 5810 | |||||||||
026B6058 | 1 | 1 | Stud | Upto 5810 | |||||||||
KSTS0210 | 1 | 1 | Screw | Upto 5810 | |||||||||
A02W0605 | 1 | 1 | Washer | Upto 5810 | |||||||||
026B0260 | 1 | 1 | Filter, Boot Floor | Upto 5810 | |||||||||
KSTS0408 | 2 | 2 | Screw | Upto 5810 | |||||||||
A02W0405 | 2 | 2 | Washer | Upto 5810 | |||||||||
026B0261 | 1 | 1 | Mat | Upto 5810 | |||||||||
A026B0265 | 2 | 20 | Guard, Rear Lamp | Upto 5810 | |||||||||
L02W0000 | 1 | 1 | Washer | Upto 5810 | |||||||||
036B0534 | 1 | Boot Floor | 1970 Federal | ||||||||||
A036B0260 | 1 | Boot Floor Extension | 1970 Federal | ||||||||||
18 | 036B1858 | 1 | 1 | 1 | 1 | Boot Floor Assembly | From 5811 | ||||||
428 | 1 | 1 | 1 | 1 | Stud | From 5811 | |||||||
DSTS0210 | 1 | 1 | 1 | 1 | Screw | From 5811 | |||||||
L03W0000 | 1 | 1 | 1 | 1 | Washer | From 5811 | |||||||
A03W0806 | 1 | 1 | 1 | 1 | Washer | From 5811 | |||||||
036B2002 | 1 | 1 | 1 | 1 | Cup Washer | From 5811 | |||||||
XUFS 0412 | 3 | 3 | 3 | 3 | Screw | From 5811 | |||||||
A04W0904 | 3 | 3 | 3 | 3 | Washer | From 5811 | |||||||
YUFN040F | 3 | 3 | 3 | 3 | Nut | From 5811 | |||||||
19 | A036B0512 | 1 | 1 | 1 | 1 | Trim Board, Boot Rear | From 5811 | ||||||
036B6123 | 1 | 1 | 1 | 1 | Tapp-it | From 5811 | |||||||
21 | 036B1859 | 1 | 1 | 1 | 1 | Trim Board, Boot Front | From 5811 | ||||||
20 | 036B1436 | 2 | 2 | 2 | 2 | Mounting Bracket, Rear Board | From 5811 | ||||||
036B1933 | 1 | 1 | 1 | 1 | Felt, Boot Floor | From 5811 | |||||||
036B0523 | 2 | 2 | 2 | 2 | Insulator, Toolkit | From 5811 | |||||||
036B0265 | 2 | 2 | 2 | 2 | Guard, Rear Lamps | From 5811 | |||||||
500B0261 | 1 | 1 | 1 | 1 | Mat | From 5811 | |||||||
A036B1933 | 1 | 1 | 1 | 1 | Mat | From 5811 | |||||||
22 | 036B0569 | 1 | 1 | 1 | 1 | Trim Board, Rear Scuttle | Coupe From 5811 | ||||||
433A | 5 | 5 | 5 | 5 | ‘Pop’ Rivet | Coupe From 5811 | |||||||
DSTS0610 | 5 | 5 | 5 | 5 | Screw | Coupe From 5811 | |||||||
KWDS0608 | 4 | 4 | 4 | 4 | Screw | Coupe From 5811 | |||||||
23 | 036B0835 | 1 | 1 | 1 | 1 | Parcel Shelf | Coupe From 5811 | ||||||
036B0571 | 5 | 5 | 5 | 5 | Bracket | Coupe From 5811 | |||||||
KWDS0610 | 5 | 5 | 5 | 5 | Screw | Coupe From 5811 | |||||||
036B6100 | 5 | 5 | 5 | 5 | Clip | Coupe From 5811 | |||||||
A036B0540 | 7 | 7 | 7 | 7 | Clip | Coupe From 5811 | |||||||
500B0569 | 1 | 1 | 1 | 1 | Trim Board, Rear Scuttle | Convertible From 5811 | |||||||
500B0376 | 1 | 1 | 1 | 1 | Trim Strip | Convertible From 5811 | |||||||
KSTS0616 | 2 | 2 | 2 | 2 | Screw | Convertible From 5811 | |||||||
036B6001 | 2 | 2 | 2 | 2 | Nut | Convertible From 5811 | |||||||
036B6163 | 2 | 2 | 2 | 2 | Cup Washer | Convertible From 5811 | |||||||
026B0757A | 1 | 1 | Trim Panel, Door Surround, LH | Upto 5810 | |||||||||
026B0758A | 1 | 1 | Trim Panel, Door Surround, RH | Upto 5810 | |||||||||
DSTS0408 | 16 | Screw | |||||||||||
16 | Trim Cap | ||||||||||||
026B0154 | 2 | 2 | Kickplate, Trim Panel | Upto 5810 | |||||||||
DSTS0408 | 6 | 6 | Screw | Upto 5810 | |||||||||
026B0376 | 1 | 1 | Trim Strip | Upto 5810 | |||||||||
DUFS0416 | 9 | 9 | Screw | Upto 5810 | |||||||||
LUFN040F | 9 | 9 | Nut | Upto 5810 | |||||||||
036B0759 | 1 | 1 | 1 | 1 | Trim Panel, Door Surround, LH | From 5811 | |||||||
036B0760 | 1 | 1 | 1 | 1 | Trim Panel, Door Surround, RH | From 5811 | |||||||
036B6169 | 2 | 2 | 2 | 2 | Coat Hook | Coupe From 5811 | |||||||
DSTS0412 | 4 | 4 | 4 | 4 | Screw | Coupe From 5811 | |||||||
036B6001 | 4 | 4 | 4 | 4 | Nut | Coupe From 5811 | |||||||
026B0243A | 1 | 1 | Tunnel Top Assembly | Upto 5810 | |||||||||
036B0811A | 1 | 1 | Tunnel Top Assembly, Std. | From 5811 to 7894 | |||||||||
036B081lB | 1 | 1 | Tunnel Top Assembly, S/E | From 5811 to 7894 | |||||||||
24 | 036B1700 | 1 | Tunnel Top Assembly, S/E | From 7895 | |||||||||
036B1701 | 1 | 1 | Tunnel Top Assembly, STD. and Federal | From 7895 | |||||||||
026B0739 | 1 | 1 | Seat, LH | Upto 5810 | |||||||||
026B0740 | 1 | 1 | Seat, RH | Upto 5810 | |||||||||
036B0739A | 1 | Seat, LH | From 5811 to 7399 | ||||||||||
036B074A | 1 | Seat, LH | From 5811 to 7399 | ||||||||||
036B1174A | 2 | Seat | From 7400 to 7894 | ||||||||||
25 | B036B1174A | 2 | Seat | From 7895 | |||||||||
26 | A036B1174A | 2 | Seat | From 7895 | |||||||||
A036B1911 | 2 | 2 | Cover, Seats | From 7895 | |||||||||
026B0138 | 4 | 4 | 4 | 4 | Seat Runner, Replaced by A026B0138 | Upto 9266 | |||||||
27 | A026B0138 | 4 | Seat Runner | From 9267 | |||||||||
XUFS0420 | 8 | Screw, Runners to Body | |||||||||||
A04W0904 | 16 | Washer, Runners to Body | |||||||||||
YUFN0405 | 8 | Nut, Runners to Body | |||||||||||
28 | A026B0137 | 4 | Clamp Plate | ||||||||||
XUCS 0620 | 4 | Screw |
