| Item | Lotus # | All | +2 | +2 FED | +2S | +2S FED | +2S 130 | RHD | LHD | Description | Change Point Notes Bulletin Reference |
| D050B0237 | 1 | 1 | + | Facia Panel | From ? | ||||||
| E050B0237 | 1 | 1 | + | Facia Panel | From Jan. 1970 | ||||||
| F050B0237 | 1 | 1 | + | Facia Panel | From Jan. 1970 | ||||||
| G050B0237 | 1 | 1 | 1 | + | Facia Panel | From Jan. 1970 | |||||
| 1 | D050B0238 | 1 | 1 | + | Facia Panel | From ? | |||||
| E050B0238 | 1 | 1 | + | Facia Panel | |||||||
| F050B0238 | 1 | 1 | + | Facia Panel | |||||||
| 2 | 050B1632 | 1 | 1 | + | Finisher - Driver’s Side RH Piece | From ? to ? | |||||
| 050B1633 | 1 | 1 | + | Finisher - Driver’s Side LH Piece | From ? to ? | ||||||
| 050B0928 | 1 | 1 | + | Finisher - Driver’s Side RH Piece | From ? | ||||||
| 050B1929 | 1 | 1 | 1 | + | Finisher - Driver’s Side LH Piece | From ? | |||||
| 3 | 050B1624 | 1 | 1 | + | Finisher - Driver’s Side LH Piece | From ? to ? | |||||
| 050B1621 | 1 | 1 | + | Finisher - Driver’s Side RH Piece | From ? to ? | ||||||
| 050B1846 | 1 | 1 | + | Finisher - Driver’s Side LH Piece | From ? | ||||||
| A050B2014 | 1 | 1 | + | Finisher - Driver’s Side LH Piece | |||||||
| 050B1847 | 1 | 1 | 1 | + | Finisher - Driver’s Side LH Piece | From ? | |||||
| 4 | 050B1622 | 1 | 1 | + | Finisher - Passenger’s Side | From ? to ? | |||||
| 050B1625 | 1 | 1 | 1 | + | Finisher - Passenger’s Side | From ? to ? | |||||
| 050B0930 | 1 | 1 | + | Finisher - Passenger’s Side | From ? | ||||||
| 050B0931 | 1 | 1 | 1 | + | Finisher - Passenger’s Side | From ? | |||||
| 5 | 050B1261 | 1 | 1 | + | Heater Valence Assy. LH | ||||||
| 6 | 050B1262 | 1 | 1 | + | Heater Valence Assy. RH | ||||||
| 050B1717 | 1 | 1 | 1 | + | Heater Valence Assy. LH | ||||||
| 050B1716 | 1 | 1 | 1 | + | Heater Valence Assy. RH | ||||||
| B050B1261 | 1 | 1 | + | Heater Valence Assy. LH | From ? | ||||||
| B050B1261 | 1 | 1 | + | Heater Valence Assy. RH | From ? to ? | ||||||
| B050B1717 | 1 | 1 | 1 | + | Heater Valence Assy. LH | From ? to ? | |||||
| B050B1716 | 1 | 1 | 1 | + | Heater Valence Assy. RH | From ? | |||||
| A050B1725 | 1 | 1 | + | Heater Valence Assy. LH | From ? | ||||||
| B050B1725 | 1 | + | Heater Valence Assy. LH | From ? | |||||||
| 7 | 050H6006 | 1 | Binnacle, Upper | ||||||||
| 8 | 050H6007 | 1 | Binnacle, Lower | ||||||||
| 050H6008 | 1 | Binnacle, Upper | |||||||||
| 050H6009 | 1 | Binnacle, Lower | |||||||||
| 050H0845 | 1 | 1 | Binnacle Assembly | From ? | |||||||
| 050H0846 | 1 | 1 | Binnacle Assembly | From ? | |||||||
| 050H6150 | 1 | 1 | Tutch Latch | ||||||||
| 9 | 036B6171 | 1 | Lock - Glove Box Lid | From ? | |||||||
| PSTS0408 | 3 | Screw - Lock Mounting | |||||||||
| 10 | A050B0621 | 3 | Mounting Bracket | From ? Upto ? | |||||||
| 050B0621 | 1 | Mounting Bracket | From ? | ||||||||
| A050B6189 | 1 | Buffer - Switch Actuating (Glove Box Lamp) |
