BB - Body - Primary Exterior
Item Lotus # All S1 S2 S3 S3 SS S4 S4FED SPRINT RHD LHD Description Change Point
Notes
Bulletin Reference
026B0001 1 1 Body Shell Upto 5810
036B0001 1 1 Body Shell, Coupe, Inc. Items 5, 11, 26, 27, 41, 42 From 5811 to 7894
500B0001 1 1 Body Shell, Convertible, Inc. Items 5, 11, 26, 27, 41, 42 From 5811 to 7894
A056B0001 1 Body Shell,- Coupe, Replaced by (056B1800 manual omission?), Inc. Items 5, 11, 26, 27, 41, 42 From 7895
A045B0001 1 Body Shell, Convertible, Replaced by (056B1801 manual omission?), Inc. Items 5, 11, 26, 27, 41, 42 From 7895
1 056B1800 1 Body Shell,- Coupe, Inc. Items 5, 11, 26, 27, 41, 42
056B1801 1 Body Shell, Convertible, Inc. Items 5, 11, 26, 27, 41, 42
045B1800 1 Body Shell, Coupe, Inc. Items 5, 11, 26, 27, 41, 42
045B1801 1 Body Shell, Convertible, Inc. Items 5, 11, 26, 27, 41, 42
C056B1801 1 Body Shell, Coupe, Inc. Items 5, 11, 26, 27, 41, 42
B045B1801 1 Body Shell, Convertible, Inc. Items 5, 11, 26, 27, 41, 42
026B0317 1 Plate, Footbox Blanking Up to Intorduction of “Handed” Bodies
434 4 ‘Pop’ Rivet Up to Intorduction of “Handed” Bodies
A02W 0405 4 Washer Up to Intorduction of “Handed” Bodies
036B0002 1 1 1 1 Frame, Door, RH
036B0003A 1 1 1 1 Frame, Door, LH
2 A036A0060 1 1 1 1 Brace, Rear Strut
3 026B0239 1 1 1 1 Bracket, Facla Support From 5811
4 A036P0003 1 1 1 1 Bracket, Heater Mounting From 5811
026B0030 1 Bonnet Lid, Replaced by C026B0030 Upto 7894
5 C026B0030 1 Bonnet Lid (with power bulge) From 7895
6 026B0031 2 Hinge Skid Plate
026B6000 4 ‘Pop’ Rivet, Skid Plate
7 C026B0034 1 Spring, Bonnet Hinge
8 026B0015 2 Bracket, Bonnet Support
PSTS1016 2 Screw
A03W0605 2 Washer
LUFN100F 2 Nut
026B0036 1 1 Cable, Bonnet Release Upto 5810
9 036B0036 1 1 1 1 Cable, Bonnet Release From 5811
036B1280 1 Bracket, Cable to Facla
050B1395 1 Bracket, Bonnet Release 1970 Federal
DWDS0605 4 Screw, Bracket
026B0377 1 Foam Rubber, Rear Bonnet
026B0033 2 2 Bonnet Catch Plate Upto 5810
10 036B0033 2 2 2 2 Bonnet Catch Plate From 5811
026B0032 2 Spring, Bonnet Catch
036B6026 4 Screw
LUFN100F 2 Nut
A03W0605 4 Washer
026B0040 1 1 Boot Lid Upto 5810
11 036B0040 1 1 1 1 Boot Lid From 5811
12 036B6030 2 2 2 2 Location Buffer, Boot Lid From 5811
XUCS0516 2 2 2 2 Screw From 5811
LUCN050F 4 4 4 4 Nut From 5811
L05W0000 4 4 4 4 Washer From 5811
026B0041 2 2 Hinge Upto 5810
026B0042 2 2 Gasket Upto 5810
LUCN040F 4 4 Nut Upto 5810
A04W0905 4 4 Washer Upto 5810
13 036B6006 2 2 2 2 Hinge From 5811
14 036B1112 AR AR AR AR Gasket, Rear Replaced by A036B1112 From 5811
A036B1112 AR AR AR AR Gasket, Rear From 5811
15 036B1111 AR AR AR AR Gasket, Front Replaced by A036B1111 From 5811
A036B1111 AR AR AR AR Gasket, Front From 5811
LUCN040F 4 4 4 4 Nut From 5811
A04W1207 4 4 4 4 Washer From 5811
026B0327 1 1 Seal, Boot Lid Upto 5810
16 036B0327A 1 1 1 1 Seal, Boot Lid From 5811
026B0044 1 1 Spring, Boot Lid Stay Upto 5810
17 500B0044 1 1 1 1 Spring, Boot Lid Stay From 5811
026B0043 1 1 Bracket, Boot Lid Stay Upto 5810
LUCN040F 1 1 Nut Upto 5810
026B0011 4 4 Plate, Support Stay Upto 5810
DSTS1008 1 1 Screw Upto 5810
AUFN100F 2 2 Nut Upto 5810
026B0016 2 2 Clip, Floor Upto 5810
XUCS0408 1 1 Screw Upto 5810
026B0017 1 1 Stay, Support Upto 5810
026B6036 1 1 Split Pin Upto 5810
18 500B0043 1 1 1 1 Bracket, Boot Lid Stay From 5811
LUCN050F 2 2 2 2 Nut From 5811
A05W1007 2 2 2 2 Washer From 5811
XUFS1008 1 1 1 1 Screw From 5811
A03W0605 1 1 1 1 Washer From 5811
LUFN100F 1 1 1 1 Nut From 5811
19 036B0495 1 1 1 1 Bobbin, Boot Stay Sprlng From 5811
XUCB0416 1 Bolt
L04W0000 1 Washer
036B6012 1 1 1 1 Bollard, Boot Lock From 5811
XUCS0408 1 1 1 1 Screw From 5811
L04W0000 1 1 1 1 Washer From 5811
A04W0905 1 1 1 1 Washer From 5811
20 036B0599 1 Clamp, Spare Wheel
XUCS0548 1 Screw, ‘Knock-on’ Wheel From 5811
XUCS0540 1 1 Screw, ‘Bolt-on’ Wheel From 5811
XUCS0520 1 1 1 1 Screw, ‘Knock-on’ Wheel From 5811
XUCS0532 1 1 1 1 Screw, ‘Bolt-on’ Wheel From 5811
036B6066 1 1 Lock Assembly, Boot Upto 5810
21 036B0803A 1 1 1 1 Lock Handle wlth Gasket
DSTS1012 2 2 2 2 Screw From 5811
LUFN100F 2 2 2 2 Nut From 5811
A03W0605 2 2 2 2 Washer From 5811
22 036B0452 1 1 1 1 Mounting Bracket, Lock From 5811
XUCS0508 1 1 1 1 Screw From 5811
L05W0000 2 2 2 2 Washer From 5811
23 036B6273 1 1 1 1 Budget Lock From 5811
XUCS0408 2 2 2 2 Screw From 5811
AUCN040F 2 2 2 2 Nut From 5811
L04W0000 2 2 2 2 Washer From 5811
24 036B1855 1 1 1 1 Side Support Bracket, Floor From 5811
60 036B1436 2 2 2 2 Mounting Bracket, Boot Wall From 5811
25 036B1856 1 Centre Support Bracket 1970 Federal From 7895
59 036B1857 1 Front Support Bracket 1970 Federal From 7895
036B1650 1 Brace, Rear Scuttle 1970 Federal
036B1145 1 Blanking Shield 1970 Federal
026B0045 1 Bracket, Boot Floor Support 1970 Federal
026B6000 4 4 4 4 Rivet From 5811
A026B0755 1 1 Door Shell, LH Upto 5810
A026B0756 1 1 Door Shell, RH Upto 5810
036B0755 1 1 Door Shell, LH From 5810 to 7894
036B0756 1 1 Door Shell, RH From 5810 to 7894
26 A036B0755 1 1 Door Shell, LH From 7895
27 A036B0756 1 1 Door Shell, RH From 7895
28 036B0309 1 1 1 1 Drip Rail, LH Coupe from 5811
29 036B0310 1 1 1 1 Drip Rail, RH Coupe from 5811
KSTS0608 16 16 16 16 Screw, Rail Coupe from 5811
30 500B0309 1 1 1 1 Drip Rail, LH Convertible from 5811
31 500B0310 1 1 1 1 Drip Rail, RH Convertible from 5811
KSTS0606 1 1 Screw, Rail Convertible from 5811
026B0029 1 1 Windscreen Upto 5810
036B6060 1 1 Weatherstrip Upto 5810
026B6038 1 1 Fillerstrip Upto 5810
36 026B0702 1 1 Windscreen Frame Upto 5810
XUCB0424 2 2 Bolt, Frame to Body Upto 5810
036B2000 1 1 Windscreen Frame From 5811 to 7894
A04W0905 2 2 Washer Upto 5810
XUFB0420 2 2 Bolt Upto 5810
LUFN040F 2 2 Nut Upto 5810
XUFS0412 6 6 Screw, Windscreen Frame to Body Upto 5810
A04W0905 12 12 Washer Upto 5810
LUFN040F 6 6 Nut Upto 5810
KSTS1016 2 2 Screw, Frame Centre to Body Upto 5810
LUFN100F 2 2 Nut Upto 5810
026B6024 2 2 Stud (‘dot’) Upto 5810
KSTS0408 2 2 Screw, Stud to Frame Upto 5810
026B0301 2 2 Eye Bolt Upto 5810
LUFN040F 2 2 Nut, Eye Bolt Upto 5810
026B0024 1 1 Tie-Rod, Frame Upto 5810
026B0025 1 1 Slotted Bush Upto 5810
026B6037 1 1 Cupwasher Upto 5810
A026B0321 1 1 Sealing Strip, Frame to Body Upto 5810
036B0029 1 Windscreen (.015 in. centre) From 5811 to 7399
036B0549 1 1 Weatherstrip From 5811 to 7399
036B6274 1 1 Fillerstrip From 5811 to 7399
35 036B0480 2 1 Corner Trim From 5811 to 7399
036B029C 1 Windscreen, Tinted (.015 in. centre) From 5811 to 7399
32 036B029B 1 1 1 Windscreen (.030 in. centre) Fitted in all Series 5 cars from 7640 From 7400
036B029D 1 1 1 Windscreen (.030 in. centre), Sundym From 7400
036B029E 1 1 Windscreen, Shaded Sundym From 7400
33 036B0549A 1 1 Weatherstrip From 7400
34 036B6258 1 1 Fillerstrip From 7400
036B1682 1 1 Sticker, ‘Running-in Speeds’ From 7895
050B1692 1 1 Sticker, ‘Lotus World Champion Car again’ From 7895
500B0024 1 1 1 1 Tie-Rod, Windscreen Frame Convertible only From 5811
LUFN100F 1 1 1 1 Nut Convertible only From 5811
036B6275 1 1 1 1 Nipple, Tie-Rod Convertible only From 5811
500B0262 1 1 1 1 Mounting Bracket Convertible only From 5811
PSTS1012 1 1 1 1 Screw Convertible only From 5811
W011 1 1 1 1 Spacer Convertible only From 5811
A03W1204 1 1 1 1 Washer Convertible only From 5811
37 036B0349 1 1 1 1 Rear Screen From 5811
A036B0349 1 1 1 1 Rear Screen, Heated (Series 4 only) From 5811
B036B0349 1 1 1 1 Rear Screen, Sundym From 5811
38 036B0555 1 1 1 1 Weatherstrip From 5811
39 036B6276 1 1 1 1 Fillerstrip From 5811
40 036B0479 2 2 2 2 Corner Trim From 5811
41 026B0119 1 1 1 1 1 Headlamp Bowl, LH
42 026B0120 1 1 1 1 1 Headlamp Bowl, RH
026B0119A 1 Headlamp Bowl, LH 1970 Federal
026B012nA 1 Headlamp Bowl, RH 1970 Federal
XUCS0420 4 Screw, Bowl to Body
L04W0000 4 Lockvasher
XUCS0420 2 Screw, Bowl Stop
XUCS0424 2 Screw
LUCN040F 4 Locknut
026B0050 1 1 Front Bumper Upto 5810
43 A036B0050 1 1 Front Bumper From 5811 to 7894
A036B0050C 1 Front Bumper From 7895 (Non-Fed.)
B036B0050 1 Front Bumper, Can be fitted back to 5811 From 7895 (Fed. only)
44 026B6039 1 Trim Strip, Bumper
PBAS0408 2 Screw, Trim Strip
ABAN040F 2 Nut, Trim Strip
A036B6179 2 Bolt, Bumper Outer Fixing
L05W0000 2 Washer, Bumper Outer Fixing
A05W1007 2 Washer, Bumper Outer Fixing
ABFN050H 1 Nut, Bumper Outer Fixing
XUCS0420 1 Screw, Bumper Centre Fixing
A04W1606 1 Washer, Bumper Centre Fixing
45 A036B0060 1 Rear Bumper
XUCB0420 2 Bolt
L04W0000 2 Washer
46 026B0269 1 Nose Badge
LUFN100F 2 Nut
A03W0605 2 Washer
026B0275 1 1 Badge ‘Elan’ Upto 5810
47 036B0275 1 1 1 1 1 Badge ‘Elan’ From 5811
026B0274 1 Badge ‘Lotus’ From 3900 to 5910
026B0280 1 Badge ‘S.2’ From 3900 to 5910
026B6041 4 15 2 2 2 2 2 Fastner, Badge
046B6027 2 2 2 Bezel, Badge From 7895
036B6024 4 4 4 Clip, Bezel From 7895
036B0501 2 2 2 Badge, ‘World Champions’ From 3900 to 5910
036B0502 2 2 2 Packing Piece, Badge From 3900 to 5910
046B6027 2 2 2 Bezel, Badge From 3900 to 5910
036B6024 4 4 4 Clip, Badge From 3900 to 5910
48 A036B2073 1 1 1 Badge, ‘World Champioms’ (1963 65,68,70)
A036B6341 1 1 1 Bezel, Badge
443 3 3 3 Clip, Bezel
49 036B0544 1 1 1 1 1 Badge ‘L’ From 5811
50 036B0545 1 1 1 1 1 Badge ‘O’ From 5811
51 036B0546 1 1 1 1 1 Badge ‘T’ From 5811
52 036B0547 1 1 1 1 1 Badge ‘U’ From 5811
53 036B0548 1 1 1 1 1 Badge ‘S’ From 5811
036B6024 11 11 11 11 11 Clip, Badge (Letters)
036B0285 1 1 1 1 1 Badge ‘SE’ From 5811
036B1425 1 1 1 Badge ‘S4’ From 5895
036B0279 1 1 Badge ‘Coupe’ From 5811 to 7894
036B6058 4 4 4 4 4 Clip, Badge From 5811
A036U0017 1 Badge ‘Elan Sprint’
036B0268 2 Badge ‘Super Safety’ From 7400 to 7894
036B0635 2 Bezel, Badge From 7400 to 7894
036B6024 4 Clip, Badge From 7400 to 7894
54 026B1023 2 2 Exterior Trim Strip From 7895 (S/E & Fed.)
050B6010 12 12 Clip From 7895 (S/E & Fed.)
036B6033 12 12 ‘Pop’ Rivet From 7895 (S/E & Fed.)
A03W0806 12 12 Washer From 7895 (S/E & Fed.)
55 026B0271 1 Heater Intake Grille
036P0013 1 1 1 1 1 Extractor Grille, LH From 5811 (Coupe only)
56 036P0014 1 1 1 1 1 Extractor Grille, RH From 5811 (Coupe only)
MSTS1012 4 4 4 4 4 Screw From 5811 (Coupe only)
L03W0000 4 4 4 4 4 Washer From 5811 (Coupe only)
A03W1601 4 4 4 4 4 Washer From 5811 (Coupe only)
57 026B0272 1 Radiator Air Intake Grille
KSTS1008 4 Spire Screw
050B6004 4 Spire Nut
036B1525 1 1 1 1 1 Grille Mesh, Engine Compartment From 5811
434 4 4 4 4 4 ‘Pop’ Rivet, Mesh From 5811
026B0373 2 Seal, Rear Suspension Access
026B0372 2 Grommet, Rear Suspension Access
58 026B0371 1 Grommet, Propshaft Access
026B6042 2 2 Seal Upto 5810
026B0188 2 2 Support, Seal Upto 5810
026B6043 6 6 ‘Pop’ Rivet Upto 5810
050B6140 1 Exterior Mirror (USA Fed.) From 5895 to 9013
A050B6140 1 Exterior Mirror (USA Fed.) From 9014
A036B2080 4 Decal, Wheelarch
A036B2078 2 Decal, Door
A036B2081 2 Decal, Rear
