How about a black-painted plate with a long ‘World Champion Car Constructors’ badge?
My +2 has a (probably home made) black plate around the radio, and my S4 has a wooden blanking piece that matches the (replacement) dashboard with a badge.
Try making something & see what it looks like…
I have been looking for a hinge that you tap and it opens. I have a remote modern radio and if the blanking plate flips up or down the radio controls will be in view. That type of small hinge is in modern cars like cup holders etc. Any ideas—could be a great after market item.
Chrisrich, if you don’t have the matching blank plate, a metal or even a finished piece of wood that is painted crackel black, like the ash tray, would look like it belonged there.
Sarto
I have the original never listened to PYE radio in my +2 and have thought hard about selling it. If I did, I’d create a small (radio size) cubby box mounted behind the dash, maybe faux interior paint job to match the burled dash, good for all sorts of things as mentioned, phone, liquor, defense devices etc; I wouldn’t bother with a door as it would look “after market” no matter how good. Just my opinion.
Actually for my use I do have a matching blank plate. The hinge would leave the dash looking untouched. I would be able to open and shut the blank plate with a touch or even a pull knob of soures. All of the hinge attachments would be attached to the back of the dash and the blanking plate leaving the plate flush with the dash. I have a small modern “secret radio” that would mount behind the dash and blanking plate keeping it hidden.
Stuart, thanks for your thoughts, lets talk.
Not to change subjects, but could you please tell us about the hand brake? Where did you get it? Did it come off another car? Does it interfere with the passenger? Does it work? I’d love to replace mine.
It’s from an E-type Jaguar. I’ve never had any passengers complain about it interfering, it is pretty flush with tunnel (but is a tight fit)
It works for a couple of minutes usually
It works good (if you can call the Elans handbrake as working good) as long as I am diligent about keeping it adjusted, which I am not, so I don’t use it
I’ll post a photo of my radio blanking plate. It’s a Healey blanking plate from Moss Motors and I put the World Championship winner strip on it.
It is a wrinkle black finish wiith 2 holes for stainless screws to secure
home made metal strips behind it.
Rgds,
Phil
Here’s a photo of my radio blanking plate. It’s a Healey blanking plate from Moss Motors and I put the World Championship winner strip on it.
Rgds,
Phil
Rgds,
Phil
On my Europa (when I still had it) I fitted the box that VW used on the mk 1 Golfs, it should also fit the Elans as the hole in the dash is the same size.
It just gives a small but useful space for sunglasses,keys etc.
