Hi all,
Did random checks to-day after the plus two was not running well. You know the oil fumes breather pipe which is connected off the rear right hand side of the engine onto the back of the airfilter box? Well oil has been coming from the engine along this pipe and has completely saturated/clogged the airfilter in about 500 miles.
I haven’t experienced this on any other cars before but suspect it has been a problem on this one from the day I purchased it. Any ideas as to causes, better still any cures?
Thanks Seaandmoor
Thanks for thoughts on that John and Sean.
The type of answers I was expecting really but (I’ll probably be wrong) I somehow think there is another contributory cause.
I’ll see what happens with the dipstick out and do the oil catch can temporary fix. (Oil level is between low and full and isn’t overfilled)
The compression is up without leakdown, there’s no puffs of white smoke out of the exhaust to suggest excessive wear and the rings/bores together all the valves/guides/springs etc in the head were only done about 2000 miles ago when converting to unleaded.
What next?
In the mean time I’ll see if there are any other clues or pointers and let you know.
Regards, Seaandmoor.
As an option for a catch tank instead of drilling/tapping your head or camcover - cliveyboy does a t-piece pipe which you can fit in place of the breather tube that blanks off the path to the airbox - you just have to engineer a catch tank off the bottom of the T.
Seaandmoor
Are we talking about clogging up an air filter thats located in the nose cone, because that is pretty severe.
Usually the air breather is just for a small bit of mist which gets sucked back into number 4 cylinder, hence number 4 spark plug usually being oily.
Couple of suggestions:-
Is the engine normal size or is it a larger 1700cc conversion. the bigger volume engines have problems with oil breathing and chuck out lots of oil especially through the breather.
Also the airbox tends to get a slight oil/fuel mix in it normally, are your carbs set up correct (not spitting back) or could it be more fuel based than oil that is clogging up the filter. (You did not mention that you are using excessive amounts of oil).
When checking the blow back up the dipstick, you will always get a small amount which is normal.
Hello Clive,
Thanks for that. For clarification… the air filter box in the nose cone is fine, it’s the back half of the standard airbox that goes over the carbs air inlets that’s clogged with oil and leaking out onto engine bay, not a lot but what a mess.
When I bought the car it had sponges over the carb air intakes which I was told was a fire risk if the carbs spat back. There was an upturned breather pipe off the back of the engine and I was getting a nasty smell of oil fumes in the car which made me feel sick.
Solution - fit original type airbox for the carbs air intake and reconnect the breather to the back of the airbox so that the original method of dealing with the ‘crankcase blow-by gases’ (page 62 Fig 27 of the workshop manual) is re-instated.
As regards losing oil, it started on the full line and after 2000mls it’s 9mm below full, that’s not much is it. No significant pressure out of the dipstick hole. You are right though about the rear plug on cylinder 4 being dirtier than the others.
So, do you think your ‘T’ piece gadget will stop the oil mist getting into the carbs airbox and still prevent the smell of hot oil getting inside the car?
Any others had experience of this problem? (whenever I take a car to the garage with a problem they always suck their teeth, scratch everywhere of their anatomy and say “very odd, never come across that before”
Thanks again, Seaandmoor
One of those Tee pieces would certainly stop oil getting into the carbs/airbox. You will also have to run a piece of hose from the tee piece to outside the engine bay preferably as Sean suggests via a catch tank.
Mine vents to underneath the car.
I know what you mean about the fumes, initially I did not use a long enough piece of hose to reach right under the car and fumes got into the cabin, (made the head spin abit)
I have a similar experience to you, but approached it slighly differently from Cliveyboy.
You can get a breather elbow to replace the breather connection to the airbox from Paul Matty, CN, ebay etc. I fitted one of these and connected to a catch tank. I find it works best if the catch tank is mounted lower than the head, and the elbow points downwards.
I connected a long section of radiator hose (5/8 or 3/4") to the connector at the head and ran ii past the engine and through a hole on the floor of the body ahead of the radiator. The head is vented and the junk doesn’t wind up in the carbs.
Considering the oil that always seems to leak from the twin cam what little oil may come from this hose is minor
I had a similar problem before I had my engine rebuilt. A rubber cork in the hole in the airbox and a longer tube from the breather hole into a catch bottle, actually a bike drinks bottle fitted under the carbs. It transformed the previously rough running at low revs.
Jim
What sort of oil are you using? Also, is it possible that you’re not using the car very often. I was very impressed with your engine when I saw it - it is you isn’t it - with the lagoon blue +2? Sorry if I’ve mistaken you for someone else. I was also wondering if your engine just needed a good thrashing to clear out moisture in the oil - maybe a couple of hours down the motorway. Is there a creamy deposit under the oil filler cap? If so, then it’s because the engine oil’s not evaporating moisture etc. 'cause it never gets a chance.
[quote=“mastijo”]
I only have 300 miles on it. The engine was completely rebuilt. I have read that the blow by may be caused by the rings not being bedded in yet.I plan to try the catch tank and monitor to see how it goes
John[/quote)
John,
Although a catch tank may help to some degree as the T.C. does not breath well, I think you have some basic problem. It sounds like you are getting blowby past the rings which means they are not sealing.
As the engine has been rebuilt I assume the pistons/bores/rings are all good
with no broken rings and the correct rings fitted the correct way round, was the engine rebored and if not were the bores de-glazed (horned) ?
IMHO it is not a good idea to use a synthetic or multi-grade oil with a rebuilt engine,the oil is just too good and does not allow bedding in. Use a stright SAE 30 or 40 grade for the first 500 miles, one way which you could try to bed the rings is to get the engine to operating temp, then drive the car in 4th gear and accerate from about 1200 rpm to about 4000rpm USEING ONLY 4TH GEAR.
Do this 7 or 8 times then run the engine normally for a few days and check if it has helped. I have done this before on verious cars and it can help in some cases if the problem is a case of bedding in.
Hi Sean and Mastijo
Difficult for me to answer for certain.
However, what I can tell you is that I’ve temporarily taken the breather off the back of the airbox and Alan Voigts changed both the gearbox oil and the Engine oil as he felt it had got the wrong type of oil in… forgot to ask him what type he uses
Also now that everythings works, it gets driven more.
The situation has certainly improved and I get very little in the temporary catch bottle.
Sooo you may both be right and I think it now time for me to order up a more permanent piece of kit from Cliveboy!
Seaandmoor.
