Hi Gary,
You make a very good point that there a wide range of Elan cars and owners, with different, and opposing, desires.
However, engineering always has to face these issues. And management has to resolve the personel issues. If we engineered a solution that satisfied 3 sigma or 95%, would there be a substantial reduction in demand? Or would this last 5% sign up for the benefits of a properly engineered solution even though they might have to slightly adapt their driving style? Would we care if they didn’t?
Since I am mechanically inept, I will shy away from a solution that has me drill, fabricate, cut, weld, machine, mill or any other skills oriented task.
But after reading this thread, I might be tempted to order a Voights kit, call Brian at BGH and order a E6/E7 gearkit, order an aluminum case from Quaife, and get a XR4ti maintenance manual on CD off of ebay (which has 60 odd pages on disassembling/reassembling the gearbox).
Then in theory, it says, I could merge Voights kit with the BGH gearkit in the Quaife case, follow Voights installation instructions and get the kit in the car.
Then I have non-standard components from the engine block to the drive shaft.
The other tack is to machine a gearset to our specifications so we have Lotus shaft lengths and splines, cast a gear case so we have 2000E bolt pattern and frame mounting boss.
The rest, as they say with a casual wave of the hand, is details. It will all plug and play.
The important thing is to get an acceptable quote from a gear cutter for the gearset and a foundry for the gearcase that, in estimated production volumes, pencils out. I had done this earlier, but my contact got sick, the shop got busy, so their written quote came in several times higher than expected. So, on to the next one. Anybody with contacts can help the group effort by getting the gearcutter/foundry and us together to talk and make a deal. Email me with names/phone numbers/email addresses.
I have met with other Elan owners here in SoCalif who have declared they are going to fit a 5-speed come hell or high water. And they have the mechanical skills to do this. So if I can’t do the job properly, I may get a hack job and the rest of the Lotus community will lose another opportunity to get a properly engineered 5-speed.
Well, back to work.
David
1968 36/7988
