After around 15 years of competition since the last rebuild the Quaife straight cut gear box in my Elan needs a refresh. I decided to build up a second competition box and swap out the current one so I would have a spare. I was also interested to try the Quaife helical close ratio gear set and see how noisy it is compared to the straight cut box and the original Elan box
I have a couple of old Cortina boxes sitting on the shelf that I picked up from wreckers about 20 years ago before they became scarce and expensive that will be donors for the rebuild so the first step is to dismantle these to see what the condition of the parts I will need to combine with the new Quaife gear set.
The first box ( black) has a remote extension but otherwise is externally the same as my current box except for a couple of ribs that were added on top of the later bell housings, a couple of ribs were removed internally when this was done
once the change rods and selector forks are removed. The rear extension can be removed. These always seem to stick solid and need careful wedging apart by tapping in the join with a sharp screw driver
The non ribbed box is Mk1 Cortina. The ribbed box is the Mk2 Cortina 2000E type box. The later box has quite a few internal improvements compared to the earlier box. Main shafts and synchro hubs for example are also different. I’m not 100% sure if they are interchangeable.
Thanks for confirming the Mk1 cortina versus Mk2 cortina bellhousing and thus gearbox as i had suspected it was that based on the pilot bearing spigot diameter difference
Yes I need to reuse synchro hubs / change rods and forks from my old boxes to use with the new Quaife gear sets which come with new shafts and all other gear bits needed . The differences in synchro hubs versions is not clear and something I will need to research once I get my 2 old gear boxes fully to bits to understand what is compatible or not with the Quaife gear sets. i always wanted to get a better idea around the issues of parts interchangeability across the various ages of three rail “2000e” boxes and now is my chance
I would guess “promotor” knows more about this stuff already and will contribute here as he does lots of diffs and gearboxes
I’ve rebuilt 6 'boxes - 4 early Cortina types and 2 later ribbed types, and have 2 more and lots of parts waiting for me to get to. The synchro rings are just one of several differences; snap ring vs. circlip main shaft, synchro rings, blocker bars, synchro hubs, and no doubt more that I’ve forgotten since it’s been a few years since I’ve been inside one.
There was a time when new replacement early type synchro rings were hard to find or very expensive. It was often the practice to modify the newer style synchro rings to allow the early blocker bars to fit, and to work with the early gearset assemblies.
I’ve successfully modified the “new” synchro balk rings to work with “old” style hubs. Two modifications are needed, first the outer diameter of the smooth section needs to be turned down aprox .100 and the three slots cut fully through. Since I have access to machine tools this was cheaper than upgrading to the new style hubs. A modified ring is on the left with an original “new” ring on the right. I don’t have an unmodified ring or I’d provide the exact measurements. Hope this helps.
Continuing with the dismantling of my 2 spare boxes
Pulling out the mainshaft ( earlier draw nut type) and input shaft ( 17mm spigot diameter type).
The synchro hubs came in two spline sizes early 1.20 inch and late 1.29 inch on the main shaft. Which I presume also corresponds to the synchro ring changes. I will explore this once I get the main shaft apart as you cant tell from input shaft spigot size and main shaft draw nut style as they applied for both style synchro hubs according to the Dave Bean manual. The later post 1970 snap ring shafts had the later style 1.29 inch spline synchro hubs which I think the Quaiffe gearset main shafts also use… clear as mud.
damage to roller bearing surface of layshaft so not reusable which is often the case when you open these up. Luckily I have a couple brand new and a couple of good used layshafts available for the rebuild so not a problem
Now to do the same to my spare “red” gearbox. This was sold to me as incomplete without the change rods and forks mechanism and front seal carrier. I bought it mainly for the centre case as the layshafts tend to vibrate and fret in the locating holes under racing loads enlarging the holes and ultimately leading to gear misalignment
All the bits of the two gearboxes… now need to explore the detail differences and select the best of the components that are needed to rebuild a box with the new Quaiffe gear set that should be delivered next week according to the tracking after I paid the import GST and customs charges.
Not sure about any cone angle change. The Dave Bean Manual says the later and earlier synchro hubs can be changed provided the correct matching synchro rings are used and that the hubs match the spline diameters on the main shaft ( which changed for the 1/2 hub in 1967). This implies the cone angles on the earlier and later gears was the same. I will explore this further once I get the Quaife gear set.
Dismantled the shafts on the 2 wrecker gear boxes I have, to determine what they have come from and whether I have enough suitable bits for a rebuild using the Quaife gear kit and new gaskets and bearings.
Most would come apart with gentle tapping if needed with a soft plastic headed mallet on the shaft end while holding the component on the shaft in a gloved hand, including the main shaft bearing which appears to be a light push fit on the main shaft. Just need to remember to remove the somewhat hidden ball in the shaft that located the 1st gear sleeve to stop rotation in order to remove the 1/2 synchro hub on the early 1st gear sleeved main shafts.
The input shaft bearings and one of the 3/4 synchro hubs that was tighter fit than normal needed to be pressed off using a bearing splitter and press.
With every thing apart I could measure up the components and compare to the excellent dimensioned drawings in the Dave Bean manual. There are multiple variations in gear and synchro components some which can be exchanged to other gearbox variations and some which cant plus variations in input shaft seal and input shaft spigot size.
The photo above compares the two shafts out of my spare wreckers gearboxes with the old main shaft from my 1968 Elan gear box which currently has a Quaife gearset in it that was installed in the 1990’s
The two gear boxes I have are both early wide ratio Cortina boxes pre 1966 . Both have the sleeved 1st gear and the resultant smaller diameter 1/2 synchro hub spline of 1.20 inches compared to the 67 to 70 draw nut version and 70+ snap ring version which did not have the first gear sleeve and used a larger 1.29 inch spline for the 1/2 hub. My original 68 Elan shaft in the photo shows these differences. The Quaife gear set uses the later 1.29 inch spline for the synchro hub so I will need to source a later synchro hub . These hubs came in two versions using the earlier synchro rings for the draw nut version and later synchro rings for the snap ring version so I will need rings to match the hub and rings that I source. Provided the rings are matched to the hub and the splines match on the shaft they are apparently interchangeable on the main shaft and gears.
Another key variation is input shaft spigot size with one of my pre 66 wide ratio Cortina boxes having a 17mm spigot and the other 15mm. Supposedly according to the Bean manual the 15mm spigot was used on semi close ratio boxes and 17 mm on all wide ratio and early close ratio boxes with the outer bearing / oilite bronze bush diameter varying with the 4 bolt ( 40mm) versus 6 bolt (21mm) cranks. Why one of the pre 66 wide ratio Cortina boxes I have came with a 15mm spigot is not clear. Maybe it was used with a later engine at some stage and the input shaft changed as the17 mm spigot require a special and thin walled and fragile oilite bush to fit into the 21mm hole in the 6 bolt crank.
The other key variation is the input shaft seal and housing as there are two housings one that suits a 1 3/8 inch seal outer diameter and one a 1 5/8 inch outer diameter. The housing I have from the wreckers suits the 1 3/8 inch outer seal while the one in my current Elan gearbox suits the 1 5/8. The inner dimension of the seal is 7/8 inch on earlier gear boxes and 1 1/16 inch on post 69 gear boxes. Not sure what seal the Quaife one uses but I have an overhaul kit from TTR coming with the gearboxes with all the required seals and bearings so I will see if the seal housing fits
After all of this it looks like I will need a new 1/2 synchro hub and rings and maybe a new front seal housing but the rest of the bits I have are enough to build a complete new box. I will confirm that when the Quaife kit arrives hopefully tomorrow.
so I where I would have gathered this impression … and it is from Lotus 5 speed gearboxes (I have an early version with 5° baulk rings, which I got overhauled in 2014, while the late version is 6° I understand)
That part of the Bean manual is not correct. The bearing sizes (and all other components except for the gears themselves) has nothing to do with whether the box is semi close or wide ratio and everything to with the production year. All of the latest design synchro hubs, etc. can be found in the 1968 onward Mk2 Cortina single rail box.
I used to know all the details quite well but memory is fading on some items in the intervening 25 years or so since I last played around with this family of Ford gearboxes!
I started on my engine assembly but discovered I did not have a new needle roller bearing to fit in the crank for the gearbox input shaft spigot so I put it aside and went back to my gearbox.
I spent the time sorting out the parts and checking I had all I needed. I decided to order new synchro hubs and rings as one new 1/2 hub was needed to fit the Quaiffe shaft that uses the later main shaft larger diameter spline and I also ordered a matching 3/4 hub and rings so the box would be consistent in using the later style and not have a mix of early and later style synchro hubs. I also ordered a new 3/4 selector fork as the one off the spare gear box was worn, the other selectors were fine. I had to also get a new front seal retaining housing as I had the early type from the Cortina gear boxes that cannot accommodate the later larger diameter seal required by the Quaife input shaft. Hopefully these extra bits will arrive next week
Photo below of the Quaife kit plus the other standard gearbox rebuild bearings and gaskets
Looking at the parts supplied the machining of the Quaife components looks excellent. The bearings supplied however are sealed which is not correct as they should be open and lubricated by the gear oil rather than grease lubricated which risks contamination of the gear box oil. I will be getting locally supplied bearings without the seals or maybe just remove the seals and wash out the grease
The drawings supplied by Quaife have me scratching my head as they do not show the full assembly and what original Ford parts are used with the new Quaife components completely. Quaife supply 3 circlips but the drawing shown refers to using two Ford circlips and one Quaife circlip in the location on the main shaft where they fit to locate the main bearing and the speedo gear. However Ford only used Snap rings not circlips so not sure what they mean. It looks like the 3 supplied Quaife circlips are to be used in this location despite the drawing. Maybe the different length speedo gears referred to below require use of narrower circlips or wider Ford snap rings for correct location of either type
The two Cortina gearboxes I disassembled had 2 different steel speedo gear which I have never previously seen a reference to. I will find out what combination of circlips or snap rings is required when I assemble the shaft to accommodate the length variation. Does anyone know where the two different steel speedo gears were used ?
i.e.
One is 6 start with number 105E-C-6 and is 22.7 mm long
The other is 7 start with number 109E-7 and is 23.0 mm long - this was what Lotus appears to have used
in all the various cars according to the manuals and they only changed the plastic gears with various diff rations and tyre sizes
The speedo drive and driven gears both appear to be selected based on the desired ratio required for accurate speedometer function - not just the driven gear. Some driven gears are linked to a particular drive gear others are linked to a different one. Note the mk1 Cortina speedo drive gears aren’t interchangeable with the later drive gears in the 2000E type box. See part number listings attached. MK2 Cortina speedo gears_20201004_0001.pdf (671 KB) MK1 Cortina speedo gears_20201004_0001.pdf (667 KB)
Thanks for the data. It looks like a whole range of 6 and 7 start steel gears and various plastic coloured / teeth count gears combinations to match the speedos on various cars. I guess my two wreckers gear boxes are out of a 1300 something and and1500 Mk1Cortina judging by the combination I had
Looks like I can select the best combination for my 3.77 diff and 165/60 R13 tyres to have a half accurate speedo
You can use the metal speedo drive gears on the snap ring boxes - even though they weren’t designed for use or supplied that way. The same can’t be said for using plastic gears on the locknut boxes - that’s not an option as they’ll just crush.
To use the metal gear you will need to make use of the 0.600" thick spacer (not in my photo) found between the bearing and speedo gear on the locknut gearbox. It’ll need shortening slightly.
The plastic gears have a groove for the ball bearing to stop the gear spinning, however it isn’t a full length groove so the gear can only be pushed up the mainshaft so far and is held in place by the circlip at the other end. The metal gears also have a groove but it is a full length one. You need something to keep the gear in place on a snap-ring box. Hence modifying the 0.600" spacer. This will sit between the circlip that holds the rear mainshaft bearing on and the speedo drive gear which itself has a circlip behind it.
The plastic gears come in two designs - the longer of the two are usually looser on the shaft than the shorter ones. I usually fit with bearing compound just to stop it moving around. If you were to use a metal gear on snap-ring box I would take this approach too.
Blue gears are 7 tooth, green gears are 6 tooth. There is a 7 tooth one that looks green but isn’t green when you see it against the other green one! You can just make this out in my photo.
White driven gears nearly always come out mangled so I don’t think they mesh very well with the 6 start gear they are normally meshed with. They’re usually only found on standard Anglias so I doubt you’ll need one.
Hi Promotor
The Quaife main shaft has a groove at each end of the speedo steel for locating it. So it looks like I dont need to use the spacer between the speeder gear and the bearing for location.
Lotus used both blue and green gears ( and other colours also) with the only the 7 start shaft worm gear. Do you know if the same coloured plastics gears were made differently were made differently to accommodate 6 starts on the worm gear or just used the same plastic gear for both and the gear could accommodate the different meshing adequately.
Sounds like Quaife were thinking when they put in the extra groove!
As for the gears I have not noticed any difference in gear tooth angles between the plastic and metal drive gears nor in any of the drive gears.
What I would say is that all of the driven gears seem to mesh better with the 7 tooth than the 6 tooth gears. If you run a driven gear over the teeth on a 6 and then a 7 tooth gear hopefully you will see what I mean. I know it’s not the same as having the gear in proper mesh but it gives a sense that something is not quite right.
The natural (22 tooth) gear is not listed as fitting with a 7 tooth gear.
The blue (25 tooth) gear is not listed as fitting with a 6 tooth gear.
Otherwise you can have any combination, although I do see damaged gears from time to time. Not sure if that is down to manufacture or another issue with not fitting the driven gear carefully into mesh in the housing.
