+2 Trim
Hello
I am looking for a couple of items, perhaps people could point me in the right direction?
  1. The under-door sill trim brightwork + clips/mounts. A source for original or alternative items?
  2. The under-dash trim, left and right ie the padding/trim between your legs and the wooden dashboard. Both passenger and driver side
Any advice (or offer to sell) gratefully received
Glenn
Genn
The under-door sill trim I would keep an eye out on ebay, the clips are available from Christopher Neil
The under-dash trim, left and right, I have them for sale.
What years your +2 ?
Matt
Hello Matt, many thanks for the advice. Andy from Spyder did suggest that the 70’s ELite/Eclat sill trim, cut back a little, would make a suitable alternative. Anyone tried this, or seen it done?
It is a 68, but with a +2S dash, as far as I am aware`from my limited knowledge. (2 sets of 3 minor gauges). Will the trim you have for sale fit? Happy for PM if you prefer
Glenn
I have a pair of Elite sill trims on my +2. I bought them at Donnington last year. They are the ‘rounded-section’ type which I think look better on a ‘rounded’ +2 than the (original?) ‘angular-section’ ones - these look better on the ‘angular’ Elite/Eclat.
They had to be cut back a bit, and I shaped & folded the ends over to close them off. This avoids using the ‘unpleasant’ bit of foam that the orignals have.
The metal clips came from Christopher Neil. They are proper +2 ones to go with the angular-section trim which is probably why they were so tight to fit… The Elite/Eclat ones are plastic.
:arrow_right: Matthew
