I am having a custom alloy fuel tank made for my +2. I have decided to use Mocal breather vent valves. As these are horizontal mount only, I need to determine the average clearance at the top of the tank. It may be the tank height will need to be lowered slightly to allow the installation.
The “parcel shelf” and speakers are above the tank. Would several people please respond with a measurement of the distance between the tank to at the breathers and the bottom of the shelf and if posssible include a photo?
It appears that using these breather vent valves should keep the vent closed to the atmosphere wheen the taank pressure (- or +) is outside vent valve purge pressure. As the valves also discriminate for liquid the vent line can now run over the top of the tank and out the origial location. Avoiding the long “over the roof” vent hoses.
I would appreciate all advice and further discussion of this. Thank you.
Bob
1969 Elan +2
