+2 Heater
I just spent nearly an hour posting progress on my +2 heater repair then the system crashed. Have the pictures instead.
The company who repaired the matrix was MRS Preston Tel 01772 736500 who pressure tested and finished paint in black.
See you all at Stoneleigh in Nov with a very warm and dry +2
Gordon
And after all that you posted it in the wrong forum! :confused:
Not in the wrong forum, it just crashed on me. Anyway, it’s back in now. Tested the fan motor just in case. Would have hated to put it all back and found the fan motor was defective. Just got the dash to put back in, steering column, radio etc. will keep you posted. Modern car dash wiring must be a piece of cake compared to all this spagette. All on a printed circuit and handy multi cable connectors. One day when I have nothing to do!!!
Gordon :smiley: :smiley: :smiley:
Gordon,
Don’t know if you have a steering lock on your car but… that item has caused me more grief than anything else in a “dash out” scenario, if only they had put an extra 6" into the cables and tucked them away. :imp:
Pete.
Pete,
No. This car is a 68 +2 with no steering lock so does not have that problem. Plenty more though due to my own mods over the years such as a brake light switch on the brake pedal instead of relying on the pressure switch. I found out the hard way that by the time the brake light came on sensed by the brake line pressure senser someone behind me put a nice dent in my rear bumper. All makes for good fun in trying to make an old car fit for modern motoring.
Gordon
So - it crashed as you were posting… what did we miss? I am re-assembling a Plus 2 that I didn’t disassemble, so your (illustrated) experience would be most helpful!
Keith
US69 50/1872 (as on the back of the glove box :slight_smile:
Keith,
Double click on my name and it will bring up my profile where by you can pick out all my posts. Anything else you need just post me. Looks like our cars are very closely related.
Gordon
Interesting you have chassis number 1007, I am currently re-building 1008 for a friend
Alex
Alex,
The heater is now back in position and I am just finishing off the dash reinstallation.
Interesting that your friends car is unit 1008. Back in 1992 I wrote to Lotus registering my new chassis and they sent me a copy of the relevent page of the famous book of unit numbers.
Unit 1008 was sold to a B Ferris, Engine No H16763 B, Invoice No 1 LK 1129, Invoice No 2 PLK 0795, Dispatch Date 15.10.68.
See you all at Stoneleigh.
Gordon
68 +2 (Rhubarb)
Gordon
I know this is a long time ago but in your opinion could a skilled man de-solder the end plates,clean out the matrix tubes and re-solder?
John :wink:
Cold
But how does a person (professional or other) know if a “matrix tube” is getting thin from corrosion and ready to burst a leak???
I had the same problem as Gordon some time ago, i was replacing a cracked rubber hose and the pipe just came off in my hand :frowning:
I stripped it and cleaned up the Matrix / pipe but the hole in the Matrix was huge (looked like some one had used there teeth to make it) i really struggled to get a nice bead stuck until in the end (with the amount of work it took to remove firmly in my head) i had a chat with a local Radiator recon firm who told me if that joint had gone all the solder will have dried out and will need re-flowing. So after thinking what would i pay not to have to remove my dash again i was happy to get a recon unit.
A man who has his hierarchy of values straight.
:mrgreen:
Randy
I take it the end plates/pipes are a " brassy" material,so making up a spacer plate of similar material would be no problem?
John :wink:
