Next stage of my 1971 130S restoration is the heater.
What is the current thinking on a compatible matrix? I have seen Fiestas and MK1 Escorts mentioned but the measurements seem to be a fair bit out compared to mine which is 275mm long, 55mm deep 153mm tall (excluding pipes).
What are people using for the replacement rubber sealing strips and heater door foam?
I have done this a few times before and use the early Fiests one. Usually from Ebay. Its a bit shorter and thinner, but works just fine. On the last one I also also fitted the electric matrix from a MK7 Fiesta below it, but thats another story so to speak. There is a thread on this somewhere on the forum.
On the the page linked to below there are pictures of my matrix arrangement. It looks like I may have used some hard solid plastic along with the silicone sealant instead of wood in this case.
