+2 Child Seats
Can anyone suggest any makes of child seat (for 17 month old) that can be used in the back of a +2 with the standard lap seat belts?
Has anyone used the new Spyder harness kit?
Matthew
Seen a Spyder harness kit fitted to a car and it looks very good. There’s a pic of the parts required at http://www.spydercars.co.uk/+2_rear_seatbe…elt_mtg_kit.htm. The large piece at the top bolts between the rear suspension turrets, using the body to chassis mounting points on the rear towers. The four lower seatbelt anchorages are fitted either side of the rear seats; one either side of the transmission tunnel and one opposite on each side. You then have two four point harnesses in the back rather than lap belts.
I’m just about to fit a kit to my car while the body is off…
Simon
